Hello there,
I hope this is not a silly question.... (I'm relatively new to the Skyline and turbos)
When I drive the car at say 4500rpm in last gear and with a steady foot at the pedal shouldn't I be reading some constant boost at the build in gauge??
The thing is, that I don't! The boost gauge hovers around 0 to -.
However when I floor it the gauge goes up (to 4) but comes down when a constant speed is reached.
I'm starting to suspect that there might be a leak in the intake system ...
Or maybe I'm not familiar with how boostlevels are maintained.
Any hints are greatly appreciated :)
Hello there,
Completely normal.
When partial throttle opening is made, the engine will not create a resistance to air flow.
It will only make pressure when the engine is under load.
Completely normal.
I see ... it dawned on me after I submitted the post :)
In other words the turbo is not delivering enough pressure to hold the engine under load ..
(Engine is breathing away all the turbo ca deliver ..)
How is it with the larger turbos then?
Do they deliver constant pressure at say 4500?
Cheers and thanks for the help ..
the turbo will not make boost unless the engine is under load over a certain RPM (Depending on what size the turbo is) the bigger the turbo the higher the rpm the engine can make boost under load
so if your reving the engine at 5000rpm and there is no load on the engine you will have no boost but as soon as the engine loads up you will get boost.
Hi there ...I think I understood ..
So if you rev the engine at a constant 5000 rpm (for example going straight on a highway in last gear) the turbo must still
be working hard and produce pressure, right?
And if you floor it then (at 5000 rpm) the turbo spools up even more thus producing more pressure than the engine can consume.. right?
And that's the moment where the boost gauge comes into positive territory ..
At a cruise (constant throttle) condition, the engine does not produce enough exhaust gas at a fast enough velocity to spin the turbine at a speed that can produce boost. This is what is termed "low load", ie minimal work being done by the engine. The engine is actually running under vacuum (just like a N/A engine).
When you start to accelerate (increase the load on the engine), the volume and velocity of the exhaust gases increases, causing the turbine wheel to spin faster, thus producing boost. For example, if you are driving at constant throttle setting on a flat road, there is no boost. When you come to an "up" hill, the engine needs to do more work to maintain the road speed. The increase in the load on the engine causes the turbo to produce boost.
Under constant throttle, boost is independent of revs. If you could "cruise" at 7000 rpm, you would still have no boost.
Maybe you should go to a website such as howstuffworks (I think that's what it's called), and study how a turbocharger actually works - lot simpler than us being here writing a "War And Peace" article on how it all works.
Hi!
HaHaHa ... no war on my side :P
I'll do my homework (though I thought I've done some) but apparently I need to read a bit more on the topic ..
It seems turbo operation is not as straight forward as I though.
The mistake I've made was the assumption that when the engine revs high the turbo is doing the same.
(and that's what you generally read)
So I was wondering why there is no boost reading at cruise level.
Nevertheless you guys pointed me in the right direction .. thanks!
(I'll be back with more 'silly' questions :P)
And btw. I got an answer on a UK site, and this guy had written about 2000 posts!
He claimed I have no boost because the swing valve would be open at cruise ... so how's that ?:P
Good nite then ..
Edited by Torques
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
