Hi All,
I'm new to the forum and the proud owner of an r34 after months of the horrible import wait!
I saved and worked long and hard to get the beast and once i can save up a bit more i want to start doing a few things just wanted to be pointed in the right direction;
I would like to upgrade the air filter from the stock box (have been looking at apexi but i dont know exactly what i would need)
Intercooler - Any brands/sizes/places to look recommended for good price and quality
Front dump pipe (pipe from turbo to the cat, mine only goes from cat back) - hope i have the terms right here =/
I then plan on tinting it etc and possibly suspension, rims and system.
Don't have a huge budget but if i know what i should be looking for then i can work towards it and do it in stages if need be.
My previous car was a 1.5 ltr lancer so this is a massive jump for me already, not looking to go too huge in terms of power or performance just
a few 'minor' upgrades. Apologies if my terms above are wrong I'm still learning and any advice or tips are greatly appreciated.
Thanks in advance
https://www.sau.com.au/forums/topic/286965-hi-all-im-new/
    • Welcome Gabriel, and thanks for saving one of the less famous cousins!
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
