Hi i'm Brendan
I run a small business (Rollcage Ind.) mainly building rollcage but can do most fabrication work
Rollcages
tube bending
fuel/surge tanks
s/s mild and ali pipework
chromoly parts
very low hourly rates and im on the sunshine coast QLD
https://www.sau.com.au/forums/topic/286990-rollcage-ind/
nice. good to see someone else on the coast offering his skills.
Would you be able to post up some quotes so everyone has an idea?
eg. 1/2 cages
surge tanks
full cages
etc etc
I might have a fair bit of work for u in a few months
https://www.sau.com.au/forums/topic/286990-rollcage-ind/#findComment-4817032
Hi all
price list
1/2 Cage - $600-$750
Full Cage $1200-$2000 (depending on number of braces and intrusions bars)
these prices are for mig welded cdw cages. I can do tig welded cages in cdw or cromoly at extra cost
surge tanks price would depend on design probably around $100-$150
i dont have any polishing gear so all aluminum would mill finish
thanks brendan
Rollcage Industries
0419750046 or pm
https://www.sau.com.au/forums/topic/286990-rollcage-ind/#findComment-4822062
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
Hi i havent been on line for a while
1)Timr33 mate i would need the car to do the bending but supply and bend for around $600 some then you can notch and weld you self
2)Yes if you require qld transport mod plate these will be around $100 dollars extra
3)yes i can if you dont brake 10s you only need a half cage with side intrusions
4) topspeed buy precut(prebend so you can notch and weld) wat do you mean and does you r32 do 8 sec on the 1/4
thanks brendan
https://www.sau.com.au/forums/topic/286990-rollcage-ind/#findComment-5074873
  • 3 weeks later...
bLaQ.bOi i think you needed to choose your question better.
Trying to keep a car 'street legal' with a cage can proove difficult. Look into the regs of your state if you're serious. Mod Plates in QLD are the equivelent to an engineers certificate, except they are affix to the car.
If you were looking into motorsport stuff, perhaps a better question would have been "Are these designed to meet CAMS/ANDRA specs??".
https://www.sau.com.au/forums/topic/286990-rollcage-ind/#findComment-5104127
yep your 100 percent correct.
i shouldnt assume he knew what i ment, reguardless. he failed to answer, i wouldnt buy this stuff, esp if it hasnt been properly designed, like if its just slapped together
https://www.sau.com.au/forums/topic/286990-rollcage-ind/#findComment-5111236
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
    • I don't even go that hard core. I just say "how do you expect me to stay, when you increase my premium, and reduce the value of the car?"   Then play a game of shut the f**k up. Most of the time it's a computer that did the adjustment, and the people will happily change it around for you.
    • You just say that the premium increase seems particularly excessive (no pun intended) and that the value decrease seems unwarranted. You say that it's not 2005 any more, and that these days Skylines are generally owned and insured only by those that have demonstrated an ability to keep them in one piece across decades, and are therefore not the horrible risk that used to be assumed. etc.
    • Have a look at JS Performance Garage, just did a bit of work on a 32 GTR.
