Rollcage Ind.
brendanw
 Share
Hi i'm Brendan
I run a small business (Rollcage Ind.) mainly building rollcage but can do most fabrication work
Rollcages
tube bending
fuel/surge tanks
s/s mild and ali pipework
chromoly parts
very low hourly rates and im on the sunshine coast QLD
nice. good to see someone else on the coast offering his skills.
Would you be able to post up some quotes so everyone has an idea?
eg. 1/2 cages
surge tanks
full cages
etc etc
I might have a fair bit of work for u in a few months
Hi all
price list
1/2 Cage - $600-$750
Full Cage $1200-$2000 (depending on number of braces and intrusions bars)
these prices are for mig welded cdw cages. I can do tig welded cages in cdw or cromoly at extra cost
surge tanks price would depend on design probably around $100-$150
i dont have any polishing gear so all aluminum would mill finish
thanks brendan
Rollcage Industries
0419750046 or pm
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
Hi i havent been on line for a while
1)Timr33 mate i would need the car to do the bending but supply and bend for around $600 some then you can notch and weld you self
2)Yes if you require qld transport mod plate these will be around $100 dollars extra
3)yes i can if you dont brake 10s you only need a half cage with side intrusions
4) topspeed buy precut(prebend so you can notch and weld) wat do you mean and does you r32 do 8 sec on the 1/4
thanks brendan
  • 3 weeks later...
bLaQ.bOi i think you needed to choose your question better.
Trying to keep a car 'street legal' with a cage can proove difficult. Look into the regs of your state if you're serious. Mod Plates in QLD are the equivelent to an engineers certificate, except they are affix to the car.
If you were looking into motorsport stuff, perhaps a better question would have been "Are these designed to meet CAMS/ANDRA specs??".
yep your 100 percent correct.
i shouldnt assume he knew what i ment, reguardless. he failed to answer, i wouldnt buy this stuff, esp if it hasnt been properly designed, like if its just slapped together
 Share
    • You've given zero info about your setup. Step 1: make sure all the standard equipment are working as they should. If they're not, go investigate why. Step 2: Make sure all your wiring is done properly. Know which RB20 you have, most likely "silvertop" a.k.a R32/A31 anything after 1989. Step 3: make sure your ECU is tuned properly. Standard will barely run in this situation.
    • Depending on your use case, prop valve will almost always be a better choice.
    • I think... in the US, Silvermax is the equivalent of BC Racing, i.e. cheap Taiwanese built suspension that gets turned for "local" conditions. Back in the day in Australia, you could get MCA street for about $1300 and they were awesome. Don't know about now... In saying that, my real world TEIN experience: I got some street basis z for my old Liberty (BR9), and they were awesome ($800-odd delivered from demon-tweeks in the UK). so Don't discount TEIN
    • yeah my RedBull X2010 on Grand Valley is only good enough for bronze... I can't hit silver arrgh.
    • 100% this. Long ago, I had a guy from the R31 club who set my BNR32 up (adjustable arms all round). He did an awesome job, was an after-work kinda thing where I had to bring a slab of beer. My car never drove better, and I stupidly got a random tyre shop to check the toe angles when I changed tyres, and they ruined the alignment. tl:dr- it takes a lot of skill to set up your car lowered from factory properly, and is worth paying the $200+ it takes.
