Hi i'm Brendan
I run a small business (Rollcage Ind.) mainly building rollcage but can do most fabrication work
Rollcages
tube bending
fuel/surge tanks
s/s mild and ali pipework
chromoly parts
very low hourly rates and im on the sunshine coast QLD
https://www.sau.com.au/forums/topic/286990-rollcage-ind/
nice. good to see someone else on the coast offering his skills.
Would you be able to post up some quotes so everyone has an idea?
eg. 1/2 cages
surge tanks
full cages
etc etc
I might have a fair bit of work for u in a few months
https://www.sau.com.au/forums/topic/286990-rollcage-ind/#findComment-4817032
Hi all
price list
1/2 Cage - $600-$750
Full Cage $1200-$2000 (depending on number of braces and intrusions bars)
these prices are for mig welded cdw cages. I can do tig welded cages in cdw or cromoly at extra cost
surge tanks price would depend on design probably around $100-$150
i dont have any polishing gear so all aluminum would mill finish
thanks brendan
Rollcage Industries
0419750046 or pm
https://www.sau.com.au/forums/topic/286990-rollcage-ind/#findComment-4822062
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
Hi i havent been on line for a while
1)Timr33 mate i would need the car to do the bending but supply and bend for around $600 some then you can notch and weld you self
2)Yes if you require qld transport mod plate these will be around $100 dollars extra
3)yes i can if you dont brake 10s you only need a half cage with side intrusions
4) topspeed buy precut(prebend so you can notch and weld) wat do you mean and does you r32 do 8 sec on the 1/4
thanks brendan
https://www.sau.com.au/forums/topic/286990-rollcage-ind/#findComment-5074873
  • 3 weeks later...
bLaQ.bOi i think you needed to choose your question better.
Trying to keep a car 'street legal' with a cage can proove difficult. Look into the regs of your state if you're serious. Mod Plates in QLD are the equivelent to an engineers certificate, except they are affix to the car.
If you were looking into motorsport stuff, perhaps a better question would have been "Are these designed to meet CAMS/ANDRA specs??".
https://www.sau.com.au/forums/topic/286990-rollcage-ind/#findComment-5104127
yep your 100 percent correct.
i shouldnt assume he knew what i ment, reguardless. he failed to answer, i wouldnt buy this stuff, esp if it hasnt been properly designed, like if its just slapped together
https://www.sau.com.au/forums/topic/286990-rollcage-ind/#findComment-5111236
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
