Hi i'm Brendan
I run a small business (Rollcage Ind.) mainly building rollcage but can do most fabrication work
Rollcages
tube bending
fuel/surge tanks
s/s mild and ali pipework
chromoly parts
very low hourly rates and im on the sunshine coast QLD
https://www.sau.com.au/forums/topic/286990-rollcage-ind/
nice. good to see someone else on the coast offering his skills.
Would you be able to post up some quotes so everyone has an idea?
eg. 1/2 cages
surge tanks
full cages
etc etc
I might have a fair bit of work for u in a few months
https://www.sau.com.au/forums/topic/286990-rollcage-ind/#findComment-4817032
Hi all
price list
1/2 Cage - $600-$750
Full Cage $1200-$2000 (depending on number of braces and intrusions bars)
these prices are for mig welded cdw cages. I can do tig welded cages in cdw or cromoly at extra cost
surge tanks price would depend on design probably around $100-$150
i dont have any polishing gear so all aluminum would mill finish
thanks brendan
Rollcage Industries
0419750046 or pm
https://www.sau.com.au/forums/topic/286990-rollcage-ind/#findComment-4822062
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
  • 1 month later...
Hi i havent been on line for a while
1)Timr33 mate i would need the car to do the bending but supply and bend for around $600 some then you can notch and weld you self
2)Yes if you require qld transport mod plate these will be around $100 dollars extra
3)yes i can if you dont brake 10s you only need a half cage with side intrusions
4) topspeed buy precut(prebend so you can notch and weld) wat do you mean and does you r32 do 8 sec on the 1/4
thanks brendan
https://www.sau.com.au/forums/topic/286990-rollcage-ind/#findComment-5074873
  • 3 weeks later...
bLaQ.bOi i think you needed to choose your question better.
Trying to keep a car 'street legal' with a cage can proove difficult. Look into the regs of your state if you're serious. Mod Plates in QLD are the equivelent to an engineers certificate, except they are affix to the car.
If you were looking into motorsport stuff, perhaps a better question would have been "Are these designed to meet CAMS/ANDRA specs??".
https://www.sau.com.au/forums/topic/286990-rollcage-ind/#findComment-5104127
yep your 100 percent correct.
i shouldnt assume he knew what i ment, reguardless. he failed to answer, i wouldnt buy this stuff, esp if it hasnt been properly designed, like if its just slapped together
https://www.sau.com.au/forums/topic/286990-rollcage-ind/#findComment-5111236
    • So it should work in my case?  I does not say R34 but it say push(i have push gearbox/clutch right now) No i wont...and i do not drift/race or do anything crazy with car so even a small box should be ok for a couple of months
    • Ha ha, yeah, I've had one following me around in my parts boxes since about 2007 I believe. Just a little iddy bit hole drilled in the one I have to let it vent out once pressure was removed from the engine side. Still no idea what I'd put it on, ha ha.
    • Just read this... Just a little bit of a wild one! Do you think the driver was testing out a new feature/device for how to lose the cops in a high speed chase?   I also suspect, if the box has a road sweeper that does magnetic metal pick up, he does a LOT of work in the machining industry. Which is what most of that looked like, machining chips from a mill or lathe. And I bet they're RAZOR sharp! And from an environmental perspective they really do need to actually collect all of those little pieces too. I wonder how many people still cop flat tires over the coming months on that road?   As for insurance company, yeah, it'd be interesting to hear what they say to the owner. But realistically, he's right, that "It's his fault". In the way that, it was his truck that spilled it, so they need to clean it up. However, neither he, nor his insurance company may bear the end cost if they do an investigation and find out it was caused by someone elses negligence (And they know who)...
    • Yeah, no matter what bad things people can say about Julian from Autospeed, he at least was capable of thinking and his inclusion of a check/relief valve in the plumbing for the Audi boost controller, that I made a copy of and used for years**, completely eradicated that problem. **It's still lying on my workbench where I put it about, um, 18 years ago and have never found a home for it!
    • I didn't actually know this! I've seen photos of the H1, mainly outside shots, and they just look "different". I guess there'd be a few little changes like nicer rims, and probably the fact they have nicer looking paint with some depth and shine, which will make any vehicles body look different to the very flat colours of the defence force.   I've watched the guys on GHPC convert their Humvee to LS1, and they've done some really nice front shock upgrade. I'm waiting for the next video on it with the rear end done. I can't remember if they've already done it, or I dreamed it, but I believe they're also supercharging theres. They will be in the future doing proper long travel suspension too.   If you ditch out your big V8, as rubbish as it must be, send it to my place. I'll let the unreliable V8 motor and box be here. I just like V8s... So I'll find something to do with it... Even if that something is just taking up valuable space in the yard. I might have something Skyline I can send back in payment... Or even Ford Barra motors  (From memory you're in Canada yeah?) So you can then play with the legendary Aussie 4L version of an RB...  Except they don't have that distinctive random miss at idle like the RB25 does.
