Item: 89 Ser 3 R31 Wagon... SLEEPER
Website: Here/Boost
Item Condition: Good
Reason for Selling: Baby on the way u know the drill
Price and Payment Conditions: $5000ONO NO SWAPS NEED CASH
Extra Info:
RB20DET
Side mount
Boost Tap
Turbo Timer
Tight Box
Engineered
Microtech LT10s
Import Dash and center console
Alpine head unit
Rego 25th Oct
Heaps fun to drive, just needs a tune
Pictures: Below
Contact Details: Tim 0401303643 or PM
Edited by de Powa
https://www.sau.com.au/forums/topic/287015-ser-3-r31-wagon-sleeper/
  • 1 month later...
  • 1 month later...
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
