Hi Guys,
I have a R34 GTT auto with 102,000km on the clock. Just did the 100,000km service with Bel garage about 2 months/2,000km ago.
The car has been fine but today when i started it, the engine sounds very rough and struggles to rev plus the whole car is vibrating slightly. I didn't want to push it past 2000rpm.
The Traction Control (TCS), Slip and Engine light are also on now.
The car can drive and the gearbox seems fine - but I'm not driving it. boost also comes on like normal so i don't think it's the turbo.
Could it be a loose connection or something serious...
Oh.. the only mods is a pod filter and exhuast.
thanks
Edited by craig V8 taffe
https://www.sau.com.au/forums/topic/287038-r34-gtt-problem/
  • 3 weeks later...
Hi Guys,
thanks
hey i got the same problem as u. the lights keep showing up and the engine seem rough n struggles to rev. loud noise come from engine n so scary. i guess it should be coilpacks problem. how's ur going?
https://www.sau.com.au/forums/topic/287038-r34-gtt-problem/#findComment-4871833
Could be defective afm. I can replicate this problem by disconnecting it:
TCS & Slip lights remain on
Check engine light on
Car doesn't idle properly
I would recommend doing a diagnostic check either with a console cable or by shorting out 2 pins on the console plug and observing the flash pattern (Theres a tutorial about this on the forums somewhere).
Best of luck
https://www.sau.com.au/forums/topic/287038-r34-gtt-problem/#findComment-4872698
  • 1 month later...
