hey guys
just wondering if anyone has pictures/information on fitment for the DC EWPs on the rb30s??
as at the moment cant seem to find anything on it...
as was just going to just a cnc machine blank plate to replace where the std water pump was...??
all info and pics would be muchly appreciated!!!
thanks
Moo :/
https://www.sau.com.au/forums/topic/287105-davies-craig-ewp-fitment-to-rb30/
I use them on my race cars.
Normally we'd just lob off the front of a factory pump and TIG weld a plate over the hole. Works well and the pump housing still fits perfectly with minimal fuss compared to machining up a new housing.
I run my pump off the Haltech switched via water temp but id recommend a controller if your ECU cant run the pump.
yea that was the other idea, just gutting the standard pump n covering the leftover hole. im running re-map but have got the dc control module with the pump so that side of things is all good, jus been staring at the block tyrna see if there is any thing easy that will still look good too...lol!
cheers mate!
Edited by moo_r32
COOL COOL, IM GETTING DAVE AT AUTOSPORT ENGENEERING TO CUT THE CONE OFF A NEW WATER PUMP AND HE IS GOIN TO WELD UP THE HOLE WHERE THE SHAFT WAS AND THEN MACHIENE THE WHOLE SURFACE OF THE WATER PUMP FLAT... SHOULD LOOK PRETTY! LOL
MYT TRY POST UP A PIC 2MORROW WHEN ITS DONE.
THANX 4 YU HELP !
CHEERS MARK
THANX 4 YU HELP !
CHEERS MARK
Ive been through 2 EWP motors that were both replaced through warranty. Both had water leak into the elec motor F#@king them up, it's more reliable holding down paper. :(
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
