r32 goodies and Some r34 parts for sale
Wolf v500 Ecu plus hand controller $2100
R32 GTR injectors $300
Rb20. possibly rb25? Oil filter Relocation Kit. Don’t know what brand. Says made in USA. Probably Gates.
Rb20det polished manifold…. $100?
Rb20 polished crossover pipe + BOV $50
Rb20/25 turbo exhaust manifold $60
Rb20 stock intercooler $35
Rb20det green label afm has a small tare in mesh. Worked fine on my car. $100
Rb20det CAS $80
Rb20det ECU $220
Rb20det rocker covers sprayed blue $50
R34gtt rb25neo turbo with heat shield and dump. No shaft play at all!! $480
Im guessing you didnt get a PM back on the controller?
nup not yet sorry. im not going to sell it separately unless i know i have a buyer for each
hey mate who does your work for you? check out the link in my sig
hey
if you can put a nistune chip in my r34 ecu and tune it for less then $700 you can do my work.
still no reply about relocation kit...??
hey sorry for the late reply
its not for sale anymore. i might end up using it. if i dont ill msg you if its still for sale
  • 2 months later...
Price drop.
Wolf v500 Ecu plus hand controller $1850
R32 GTR injectors $230
Rb20. possibly rb25? Oil filter Relocation Kit. Don’t know what brand. Says made in USA. Probably Gates. $70
Rb20det polished manifold…. $50?
Rb20det CAS $80 SOLD
Rb20det ECU $150
Rb20det rocker covers sprayed blue $40
R34gtt rb25neo turbo with heat shield and dump. $370
hey buddy,
have you still go that ECU for sale???
if so i need it for a R34. will if work??
thanks
V
hey mate.
yes i still have it
no it wont work with an r34. you will need to purchase an r34 adapter from wolf or have your loom rewired.
thanks
Edited by beRwick_GTRage
  • 4 months later...
  • 1 month later...
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
