Hi, new here and i got a 32 that has a blown motor and is coming out to get rebuilt.
now wat will be the easiest way? seperate motor from box and take it out that way?
or leave it all connected and pull the whole lot out?
any help would be greatly appreciated
Cheers
JD
https://www.sau.com.au/forums/topic/287154-pulling-rb20det-out/
Are you sure you should be doing this if you're asking the question?
I realise that everyone has to start somewhere and I applaud the effort but I hope you have someone with you to assist and aid you with the job who has a little mechanical knowledge, or at the very least a comprehensive manual to work with.
In saying that, if there's no need to service the box, leave it in. Trying to manipulate the engine and box without an adjustable engine leveller/stabiliser would certainly see a few dents accumulate in the engine bay.
Good on you for giving it a go, I hope it works out man.
i never said i hadnt done it before lol
i have but last time it was on a written off car and we cut the rad support and pulled it straight out
this time is is a street car and needs to be done properly haha
i pulled an sr out last week but that was for a conversion, im just getting opinions here as to wat others would do
The difficult part with the RB20 is getting the 2 top bolts holding the box to the block.
Nothing 4-5 extensions and a wobbly drive won't sort out for the passenger side one. The other key to this is to temporarily drop the gearbox crossmember which tilts the whole lot back to allow enough room to get the socket on.
Use a stubby spanner for the drivers side after reconnecting the gearbox crossmember.
I recently took a RB20DE out to replace with a RB30DE.
I separted the gearbox from the engine leaving the gearbox in place. If you support the back of the gearbox on a trolly jack and undo the cross member this will allow sliding the engine/gearbox forward a couple of inches to get at the top gearbox bolts. I then bolted the cross member back in with the rear bolt holes of the crossmember bolted to the forward holes of the body to hold the gearbox forward. I then supported the front of the gearbox with the jack to separate the engine. Naturally the radiator and air con radiator needs to be out to slide the engine forward.
I lifted the engine out and in without the need to tilt it. Theres enough room with the radiators out.
Nigel
Edited by Nigel Nichols
Whenever I remove an engine, I separate it from the gearbox.
haha yeh they are a bitch to do lol, i replaced the gearbox not long ago and they sucked lol, went to bunnings, bought two 2 dollars spanners and cut n shut lol, it works haha
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
