As topic states, when clutch is disengaged in neutral, I can hear a tapping noise, originally I thought I had a sticky lifter. I put the clutch in and sound goes away.
Anyway, now while i'm driving, I can hear a funny noise almost like a tap/whine (it's a strange sound I really can't explain it, almost sounds like a car from the Jetsons lol). I could be stationery and rev the car and still hear this sound..
I'll try and record the sound and post on youtube later on.
Any ideas before I go to my mechanic?
Cheers.
https://www.sau.com.au/forums/topic/287177-ticking-sound/
Hey, i got it too, taps and disappears as soon as the clutch it touched, even slightly.
its most probably a thrust bearing in your clutch. dunno if much can be done apart from replacing the clutch, but i dont think it poses much of a problem.
Ive asked around and people say it isnt bad, just annoying, im not sure tho
https://www.sau.com.au/forums/topic/287177-ticking-sound/#findComment-4815800
Does it produce the noise in any of the gears or just in neutral?
Thrust bearing noises 99% of the time occur when putting the clutch in, so you can probably rule that one out.
I would say you have a neutral rollover sound, probably one of the cluster bearings on its way out. It's definitely gearbox related - well done on identifying and providing a detailed description of symptoms, it's refreshing compared to the usual "I have a weird noise coming from somewhere in my car...help?" crap that gets posted in here. The unfortunate reality is that you will need the gearbox pulled apart / reconditioned to replace this bearing. And the other unfortunate reality is that rollover noises are difficult to get rid of completely, because the longer the gearbox goes on without getting this bearing replaced, the more it wears on static parts such as shafts and gears. Then after their tolerances are reset, these parts will make something of a similar sound even with new bearings...just quieter.
https://www.sau.com.au/forums/topic/287177-ticking-sound/#findComment-4816118
heh, so after a little bit of my own investigation i went into the garage and started the car up and decided to fiddle around and see if I could pinpoint where the noise was from.
Completely unrelated... Sound is coming from timing cover... Timing belt did get changed a year ago though. I went down to my mechanic and we tested cam timing solenoid... Pull connector off and its filled with oil!
I thought it was coming from box as I heard a noise emanating from it recently.
Thanks for the replies!
https://www.sau.com.au/forums/topic/287177-ticking-sound/#findComment-4816792
So it wasnt the clutch or box at all? Has the noise gone away? Well my belts got changed at the start of the year so might get that checked out soon too
https://www.sau.com.au/forums/topic/287177-ticking-sound/#findComment-4817675
yeah dude, the sound of the ticking in clutch was recently in some REALLY cold weather, im talking like 3 deg outside. In the warmer weather, no problem no noise.
But yeah, I'm just gonna buy some adj. cam gears while we do the solenoid, labour will cost same, as timing gear needs to come off anyway.
I hear its possible to gain anywhere from 10 to 20 extra kw with cam gears.
https://www.sau.com.au/forums/topic/287177-ticking-sound/#findComment-4817783
Cam gears can provide benefit as a support modification to others...you won't see a great deal of power increase from them unless you put in some higher lift / longer duration camshafts or have a tunable aftermarket ECU / piggyback. About the best you can do with them is advance the timing on a stock setup.
https://www.sau.com.au/forums/topic/287177-ticking-sound/#findComment-4818046
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
