  • Replies 112
if you were to bolt that manifold onto a car and the car not being able to control boost.
then yes it is defective in design.
i dont see the point in having a manifold that cant control boost....what good is it?
EDIT::
okay i just realised that manifold has twin exit points. if even after having 2 wastegates and still being unable to control boost, id pity the fool who bought one.
Edited by Jap_Muscle
Eitherway, there doesnt seem to be any manifolds with a merge collector design that have wastegate placement spot on and work perfectly in aus at a reasonable price.
If there was one, im sure they would be making an absolute killing over the other couple of manifold makers who have been making them from the get go.
Anyway, abit slow, but this is what I did on our race car setup.
So Jap_Muscle....whats the answer to the problem?
the answer is to increase the diameter of the pipe that leads to the wastegate.
im not 100% sure but just thinking about what you guys have done (wastegate on the housing) your affecting the airflow in the housing which had millions of dollars spent on it for the design of airflow.
i had the exact same problem on a previous setup. we removed the exhaust and had the manifold venting to atmo to confirm it was indeed the exhaust that was the problem. And it was still making 23psi which is crazy.
we took off the manifold off and increased the pipe to the WG to 60mm and attached a 60mm gate.
problem solved.
Michael, you can call any manifold maker and ask them specifically to make the pipe to the WG larger. theres nothing hard about it.
I havent needed to go to a 60mm wg, since my 48mm progate has worked fine how it is now. We had boost control issues whilst on the manifold, even with an increase in wastegate pipe size which kyle did to help fix this issue, but it didnt work, but that was a couple of years ago now. Since then I put the wastegate on the housing as pictured and we now have perfect boost control.
Everyone seems to think it might affect flow....it very well may, but in terms of power and response, it made absolutely no difference to power, response on the dyno or at the track. There appears to be absolutely no downside to this mod atleast from what ive noticed over the last couple of years of running it.
But if your larger outlet idea works well for you then thats great...saves modifying the housing. However if everyone who runs a merge collector manifold and has to run atleast a 60mm wg just to get proper boost control...that could be quite costly. Especially since you dont really need such a large wastegate to control boost(in terms of gas flow).
Edited by r33_racer
So are you also saying that the Full Race manifolds are of 'poor design' aswell?
TOTALLY different, the twin scroll manifolds have a gate for only 3 cylinders each so they can get away with it. the Full Race item has twice the gate flow as a single the popular xyz branded manifold.
Unfortunately i don't have any pics of the modded manifolds but it is a fair amount of work to make them hold boost (the easiest was to enlarge the hole and run an oval gate take off point) .
Edited by URAS
EDIT::
I still don't see how you say someone is a fool for buying a manifold that 99% of people recommend. Are you calling yourself a fool given you had the same problems??
which is poor design
aint you also running his manifolds?
it actually means the manifold is working too well. thats why etm and 6boost recommend mounting it iff the housing. the purple rh9 r34 does this, aswell as lots of other big setups.
you misunderstood.
what i was saying was if that manifold had all 6 cylynders venting to 2 WGs and still not being able to control boost, i dont see it as a very well designed manifold.
but someone pointed out that its 3cyl per WG....which should have no problem wat so ever.
i have purchased a 6boost manifold on my earlier setup, apon realizing the problems it had with my setup, on my second request i asked that certain things be changed, and i dont have a problem now.
thats all im saying.
but i think we are going slightly off topic here, if you guys would liek to talk about what makes a good manifold feel free to create a new thread.
On the last page i posted a picture of the Heat Treatments Racing Gtr. For those that dont know, this is the car that holds the GTR world record. It has the wastegate mouted off the exhaust housing due to better boost control. If the fastest rb26 in the world has issues with controlling boost (or its so much better from the housing), id say its probably not solely a manifold issue.
True, but if room wasn't an issue a properly built manifold wont have an issue, the housing is a quick easy job whereas making a manifold with enough room between collector and turbo flange to accept the correct size and angled (proper angle should follow exhaust flow not be a right angle) wastegate exit pipe is a far harder job. all the Decent jap ones ive seen (at signal) with T88's and T51's tend to have either two feeds into the one gate pipe or a large exit pipe that comes out nearly vertical and then does a 180 back down to the gate.
This is a dodgy paint version of one of the fixes, this pic does not show the correct exit radius (looks like a 90 but its more like 60 when done correct) but it gives the general idea. In the origin pic you can see the gas need to pull more than a 90 degree turn to exit the gate pipe, we oval the hole and take a large radius 90 (bigger diameter) and angle cut the manifold end and merge it (final gate position depends on the setup) that way we increase the volume but reduce the exit angle (reduce it by half) from the merge. On one setup for a mate we actually ran double gate exit points merged to a single gate but it was ALOT of work and not feasible to do as a charge out job.
Edited by URAS
pretty good for a paint drawing trent...it explains what you mean well enough.
My idea was similiar to yours except to protrude the top section of the pipe into the collector 5-10mm to actually disrupt the exhaust flow and force it into the outlet. Even with that i dont think you would notice any difference in lag/spool from the upset flow.
its a bit hard to apply the same concept of 1000+hp cars with ours.
the reason those cars have WGs off the housing is because of the extreme applications those things run.
so you are willing to dismiss that way of mounting the gate because its on a big dollar big hp drag car yet you think it's 'dodgey' and not the best way to run the gate, i woulda thought the average joe with his street car would opt for the more pocket friendly option and the big dollar race team outfit who spends thousands on r&d and engine development would use the more expensive and best option available. maybe you should get in contact with the guys at heat treatments and let them know theres a better way of running the gate :D
My 6boost manifold has the gate pipe on an angle, I was originally worried that it would be a 90deg exit but was quite happy to see that it was on a healthy angle.
Engine isn't together yet but when it is I'll report back with any boost control issues. Setup is pretty much the same as TiTANs'.
I will mention however, that Kyle (6boost) advised I ditch the 44mm TiAl gate I had to go for the bigger 50mm Progate as his manifolds, on RB engines, had trouble controlling boost under 20psi with smaller than a 50mm gate.
Edited by bubba
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
