Why would you bother with an L20ET?
Just bung in an L28E and associated turbo gear (yank ebay would be your friend for stuff like L28ET manifold and injectors, afm, ecu etc). Will end up about 1,000,000,000,000x better off than modding the L20. Simple maths, 40% more capacity is going to make a massive difference.
L28ET & L20ET exhaust manifolds are the same. If I was going into a rebuild like this again, I would be using an L24E block, bore it 1.0mm (.040) oversize, L20B pistons and go from there. The L28E conversion is a bit tricky and sometimes a pain in the ass, for the advantages you get.
Decide first what your going to do with the car before going crazy with the engine.
Cheers, D
  • Replies 83
Cheers, D
^agree!
keep an eye out for an L26, grab the crank and rods (basicly a stroker kit!)
find an L28e intake manifold (flows better than the L20et, simpler too)
find a L24e
( cheap as chips, find another wreck R30, series 1 has E88 head, better for turbo)
rebuilt VG30 turbo, pretty much the size matching is the hard part.
Kelford Cams in NZ have some good turbo grinds, like a 256 duration turbo grind, free shipping to Aus too.
Hose tail injectors, VL turbo are 270cc or so, L28et same, just harder to find.
KA24e Throttle body, in the Ti fwd Pintara, efi 2.4 navara, ford corsair ghia 2.4 (ita 60mm DIA)
a throttle body space is required to keep the stock linkages. im looking at converting to cable though
find a L24e
You is a bit too late Mr MAG's & some of your info is wrong.
L28et injectors are 285cc & FJ20et are 375cc, both hose tail connection.
And they eazy to find .................... just gotta know where to look lol
Cheers, D
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
