Hi guys,
Last night I was assembling my 26/30 I've just built from what was left of the rb26 out of my r34 gtr.
I went to line the clutch up as you do with an old input shaft that I have used previously to line the clutch up on my r33 gtst however it wouldn't fit :S
Does anybody know if the input shaft of the getrag 6 speed from the 34 gtrs or if gtrs in general have a different input shaft compared to the gtst?
I've tried a search but came up empty :blush:
Thanks in advance!
Mark
yeah you need a clutch to suit the getrag input shaft. the 34 GTT or 33 GTST box is not a getrag. the 6 speed GTR box is completely different and input shaft is different size and splines. to top it off the old nismo 34 GTR clutch kit came with a new input shaft for the getrag box as they were a known weak point (twisting I believe) so you may be unlucky and find that the previous owner had a nismo clutch and now you'll need a clutch to match that particular shaft.
hang on, just realised you just want to align the clutch before you fit it up yeah? you actually still have the gearbox to mate up. well some driveline place should have a clutch aligning tool that will fit the getrag type clutch. sorry for the useless rant above! lol. shouldn't be more than $20 or $30 for a getrag type clutch alignment tool.
Thanks for the answers guys!
Yeah, kind of what I suspected :blink:
The previous owner told me that when he had the clutch changed by Advan in Sydney they had great trouble in finding one that would fit and the comment from the mechanic was that the gearbox wasn't standard the standard r34 gtr box, which I did find rather hard to believe :blush:
I guess it would make sense that I may have a Nismo input shaft.. Could you be nice enough to link me somewhere that has details on how I could identify the Nismo item compared to the stock?
Cheers :)
 Share
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
    • Deeve, I don't suppose that you've made any progress on this? My Stagea has the exact same problem, and just like you, I've read through as much as I can online, with no real progress. My car isn't throwing any codes at all, which is a little frustrating. I've changed plugs, checked the wiring and harness. A new MAF gets here next week, but I'm not hopeful it will solve the issue.
