Hey Everyone,
Just a quick update from CV Performance.
We straped Paul's awesome R32 GT-R onto the dyno today for some more tuning.
On 30psi of boost we made 673kw at all four.
The sound of this beast on full noise is something that need to be experienced in person to really appreciate how good it is.
I'm sure Paul will come into this thread later to elaborate on the details of the car.
Enjoy the pics, videos to come later.
  • Replies 57
fark, that's a huge discrepancy. is that after your last tune when you thought you had the issue sorted?
did you get it checked on another dyno and find it to be 55kw down on the CV dyno figure!!!?
there's prob a thread on it somewhere that i missed
yes had it checked on two other dyno's afterwards, both mainline dyno's...just power runs "no difference in tune".
initially went for boost drop issue...was claimed as cleared n sitting at 280rwkw..took it to two dyno's for power runs...came up at 225rwkw-230rwkw...so quite a difference.
freak occurance??
Edited by allthewaytotheskyline
all i can say is this car is absolutely SPASTICCCCCCCCCCCCC on the streets , i drove with it one night when he only has a run in tune 550 kw's and i cannot describe how loud and how awesome it sounded .
well done paul .
Does he run filters on the street ?? If so ....how ? (i assume those really short K&N ones ....) mainly the rear turbo, looks like its pretty tight in there !
Well done though... when does he take it out to the drags ?
Gary
AFR's between 11 and 10.. seems a little rich.
edit: beaten by paul.. curses ! hope your running copper plugs cause they are gonna foul up pretty quickly with that much fuel.
drum of roo on the front seat makes the little rich figure a lot richer...it isn't tuned the same as petrol. i.e. it really likes to be a tad leaner than normal.
there may be a reason or scaling factor error...just surprised me a little thats all
good figure...time to race it now guys.
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
