I think we need to add Genie Exhausts Dyno to the list of generous dyno's in perth, what do you guys think?
I ran a nice r33 that had just had a fresh 300+rwhp dyno on this dyno and made it look a tad slow. I'm damn sure I don't have anywhere near this much, let alone more( neither would he).
His car - fmic, EBC - 13/14psi, s-afc, full exhaust, bov.
He seemed a little confused after I told him he didn't have that much power.
https://www.sau.com.au/forums/topic/2873-big-hearted-dynos/
Originally posted by IMACUL8
Genie dyno is rooted....
Its actually set up for the LS1 motors.... the correction on it is bullsh*t.
And YES Genie is at the top/started the list for crap dyno readings....
Dan
That means the speedworks silvia's 700rwhp is probably more like 400 or so(not that its a bad figure). Good dyno to go to if you want to claim australia's highest dyno reading for a SR20DET?
https://www.sau.com.au/forums/topic/2873-big-hearted-dynos/#findComment-50785
Reason why the Genie dyno reads high is cos its a DynoJet dyno which has a 15% drivetrain loss compared to 27% of a Dynodynamics.
FWIW, the JUN motor made 590rwhp at Motorvation on Formaz's Dynodynamics dyno with a few more revs left to be had in it (hit the speed limit of the dyno)
https://www.sau.com.au/forums/topic/2873-big-hearted-dynos/#findComment-50940
Yes I've heard the Formaz unit has a speed limit issue, a number of the cars at motorvation had this problem (notably the V8s with tall diff ratios). It also seems to read a little higher than some. If the guys take it to PSI I'm sure it will still pull some great numbers with that soccerball sized turbo!:D
https://www.sau.com.au/forums/topic/2873-big-hearted-dynos/#findComment-51012
  • 2 years later...
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
