I think we need to add Genie Exhausts Dyno to the list of generous dyno's in perth, what do you guys think?
I ran a nice r33 that had just had a fresh 300+rwhp dyno on this dyno and made it look a tad slow. I'm damn sure I don't have anywhere near this much, let alone more( neither would he).
His car - fmic, EBC - 13/14psi, s-afc, full exhaust, bov.
He seemed a little confused after I told him he didn't have that much power.
https://www.sau.com.au/forums/topic/2873-big-hearted-dynos/
Originally posted by IMACUL8
Genie dyno is rooted....
Its actually set up for the LS1 motors.... the correction on it is bullsh*t.
And YES Genie is at the top/started the list for crap dyno readings....
Dan
That means the speedworks silvia's 700rwhp is probably more like 400 or so(not that its a bad figure). Good dyno to go to if you want to claim australia's highest dyno reading for a SR20DET?
https://www.sau.com.au/forums/topic/2873-big-hearted-dynos/#findComment-50785
Reason why the Genie dyno reads high is cos its a DynoJet dyno which has a 15% drivetrain loss compared to 27% of a Dynodynamics.
FWIW, the JUN motor made 590rwhp at Motorvation on Formaz's Dynodynamics dyno with a few more revs left to be had in it (hit the speed limit of the dyno)
https://www.sau.com.au/forums/topic/2873-big-hearted-dynos/#findComment-50940
Yes I've heard the Formaz unit has a speed limit issue, a number of the cars at motorvation had this problem (notably the V8s with tall diff ratios). It also seems to read a little higher than some. If the guys take it to PSI I'm sure it will still pull some great numbers with that soccerball sized turbo!:D
https://www.sau.com.au/forums/topic/2873-big-hearted-dynos/#findComment-51012
  • 2 years later...
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
