Hopefully tomorrow I will have secured a complete series 2 Stagea manual cradle.
Should solve my problem.
Just need to buy new rear forked shocks. It is a shame I just put in a set of new bilsteins in 200k's old. I am sure someone will want them
seems pointless to me? you could run an s14/15 frame and keep your current struts?
I loose $100 on a pair of struts, but gain bigger drive shafts and mechancial lsd
Not too sure if I will break 5 bolt R33 gtst shafts, but not too keen to find out and have to spend more later buying the right gear
if ur interested i got a pair of stock rs4s rear shocks and springs layin around. u can have cheap if u want em. PM me
Thanks, but I have new bilsteins up front as well, plus need to be height adjustable.
Might sell the complete f & r bilsteins, I find them too stiff. Preferred the Teins I had before
  • 5 months later...
I thought I would post an update.
I had 3 reasons to change my rear to a manual/260rs version
1. My rear cradle was a bit rusty. Could have fixed it but could not be bothered
2. To reduce the rear track by 50mm to match the front end so I can run the same offset wheels front to rear
3. Fit the larger diameter 6x1 bolt drive shafts and mechanical lsd to handle the power upgrades.
So I bought a manual rear end out of a wrecked stagea.
When I got around to changing it over, I discovered that my car, originally a series 2 auto, had the bigger drive shafts.
Basically it is the same as the manual rear end, but is 50mm wider in track.
It had the 6x1 bolt half shafts. The tail shaft is also alot heavy than the standard auto version.
I will also have to check the size if the bearings in the rear hubs as I know GTR's have bigger ones than the gtst version
Not sure if the auto diff is mechanical, but could be?
So I assume this rear end was a factory option?
Have you run your vin through fast before, and checked the options? I know a LSD rear end was an option for the S2 auto's, perhaps this also meant the stronger tail & drive shafts were used to go with it. You may have the LSD option.
  • 2 years later...
  • 2 years later...
  • 5 weeks later...
R34 non hicas craddle and half shafts bolted straight in and wheel alignment without any issues. S1 c34 converted to manual. Wheels that went in were 18x9.5 +12 with a 235/40/18 tyres. Has the slightest amount of poke on the front and rears and near on flush
  • Like 1
  • 1 year later...
So I'm looking to change over to a complete 33gtr rear end. Will there be any issues I run into at all?
Getting a new set of coilovers also so I'll be able to just get rears suit 33gtr.
I'm thinking entire rear so I can fit my wheels without doing flares and while only running -2° camber, changes shafts and diff which was my initial plan anyway.
Car is s1, wheels are 19x10.5+18 SSRs
Excuse my primed bonnet [emoji23]
I got an R32GTR rear - I think you may need to remount the Attessa unit.
The master unit?
How did you go fitting 32gtr rear subframe? Offset spacers or bolt up?
8 hours ago, GroceryZilla said:
The master unit?
Sorry can't help you with the nitty gritty because I got my local RB guru to do it on a hoist in his workshop. All I know is that the attessa pump etc had to be relocated and I had to chase round for 6 x 1 axles of various lengths (different left and right).
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
