This problem started for me about 4-5 weeks ago after changing my R32 GTR's standard airbox filter for a BMC filter. I don't think this is causing the problem but thought I'd mention in case somebody works out what may have been accidently knocked/loosened/detached, etc...
Since then the car has begun having intermittent issues accelerating (both gentle and hard) and occasionally stalls. Stalling can occur immediately after starting or driving for a while, but it does seem to occur most when either coming off the accelerator or sitting at lights. It does it on both hot and cold days regardless of temperature.
The Car's Modifications:
Blitz ECU
Fully Rebuilt and Reconditioned Engine with Competition Rings/Bearings/Gaskets/Seals)
Machined crank and fitted crank snout
Forged Pistons
I Beam Conrods
ARP Rod Bolts
Tomei Adjustable Cam Gears
N1 Oil Pump
Modified Water Pump
Tomei Sump Baffle
Front Pipes/High Flow Cat/3.5 Inch Evolution 2 Trust Exhaust System
Hi Volume 500hp Fuel Pump with upgraded negative wiring
Boost set to 1 bar
OS Giken Twin Plate Clutch
New Battery
Steps taken so far:
Induction system smoke tested for leaks
Airflow meters cleaned
Idle Air Control Checked
New Spark Plugs
New Fuel Filter
Injectors serviced and tested
Standard Coil packs checked
Engine cover removed to confirm if overheating (no difference)
The intermittent nature of the problem is making it difficult to pinpoint and therefore difficult to resolve. The only thing confirmed severely damaged is my wallet! (:))
Any and all wisdom appreciated.
Allow me to resolve this issue so that I can go on to build a finincial empire that will bring world peace and end poverty!!!
On a side note, is this a similar issue I sometimes have?
Boosting hard and then coming to a very fast stop with a very fast drop in RPM usually causes a stall or a drop to 0rpm and quickly puffing back up again. It idles perfectly though.
What turbos (just outta interest)
They are not listed and it makes me wonder why you would have a built motor, and stock AFM's does not really work (stock AFM generally means stock turbos)...
If it is stock turbos then i hope you realise you are playing with death by using the stockers :D
If it is stock turbos then i hope you realise you are playing with death by using the stockers :thanks:
They are the standard turbos.
Initially, when I bought the car, I was going to do the usual thing and just modify everything EXCEPT the engine (e.g. intake/exhaust/turbos, etc...).
However, the engine disagreed, and let me know by blowing itself to kingdom come. Next thing you know I'm doing an engine rebuild, and decided to do the job properly in anticipation of future modifications. The standard turbos were checked and found to be in excellent condition, and I was told that they are safe and reliable as long as I do not exceed 1 bar of boost.
Thanks very much for your input! It is much appreciated! :blink:
Excellent condition or not means nothing. Simply because you cannot truly tell without pulling it apart.
They are 15-20yr old turbos in most cases.
I would be backing off to 10psi with a built motor to be honest mate. You'll have better odd's in a casino, as they are not reliable at all when getting old and running 1bar.
I'd only run 1bar on low km R34 GTR items on a built motor, and even then i wouldn't sleep easy @ night knowing the trouble just one full throttle squirt can cause.
I'm not trying to scaremonger you here either, i just hate seeing people loose big engines for silly things.
Roger that. Will take it on board.
Anybody else have any other opinions on the acceleration/stalling issue I'm experiencing?
Until you swap out the AFM's with a known working set - its going to be a bit hard for any further advice from most corners as its almost pointing soley to one or both AFM's intermittently playing up.
Could be as simple as an electrical short in the AFM wire and plug..
Try playing with the AFM wire and plug while idling... Any consistant changes in idle or cutting off would indicate a short
Edited by shinaka
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
