This problem started for me about 4-5 weeks ago after changing my R32 GTR's standard airbox filter for a BMC filter. I don't think this is causing the problem but thought I'd mention in case somebody works out what may have been accidently knocked/loosened/detached, etc...
Since then the car has begun having intermittent issues accelerating (both gentle and hard) and occasionally stalls. Stalling can occur immediately after starting or driving for a while, but it does seem to occur most when either coming off the accelerator or sitting at lights. It does it on both hot and cold days regardless of temperature.
The Car's Modifications:
Blitz ECU
Fully Rebuilt and Reconditioned Engine with Competition Rings/Bearings/Gaskets/Seals)
Machined crank and fitted crank snout
Forged Pistons
I Beam Conrods
ARP Rod Bolts
Tomei Adjustable Cam Gears
N1 Oil Pump
Modified Water Pump
Tomei Sump Baffle
Front Pipes/High Flow Cat/3.5 Inch Evolution 2 Trust Exhaust System
Hi Volume 500hp Fuel Pump with upgraded negative wiring
Boost set to 1 bar
OS Giken Twin Plate Clutch
New Battery
Steps taken so far:
Induction system smoke tested for leaks
Airflow meters cleaned
Idle Air Control Checked
New Spark Plugs
New Fuel Filter
Injectors serviced and tested
Standard Coil packs checked
Engine cover removed to confirm if overheating (no difference)
The intermittent nature of the problem is making it difficult to pinpoint and therefore difficult to resolve. The only thing confirmed severely damaged is my wallet! (:))
Any and all wisdom appreciated.
Allow me to resolve this issue so that I can go on to build a finincial empire that will bring world peace and end poverty!!!
On a side note, is this a similar issue I sometimes have?
Boosting hard and then coming to a very fast stop with a very fast drop in RPM usually causes a stall or a drop to 0rpm and quickly puffing back up again. It idles perfectly though.
What turbos (just outta interest)
They are not listed and it makes me wonder why you would have a built motor, and stock AFM's does not really work (stock AFM generally means stock turbos)...
If it is stock turbos then i hope you realise you are playing with death by using the stockers :D
If it is stock turbos then i hope you realise you are playing with death by using the stockers :thanks:
They are the standard turbos.
Initially, when I bought the car, I was going to do the usual thing and just modify everything EXCEPT the engine (e.g. intake/exhaust/turbos, etc...).
However, the engine disagreed, and let me know by blowing itself to kingdom come. Next thing you know I'm doing an engine rebuild, and decided to do the job properly in anticipation of future modifications. The standard turbos were checked and found to be in excellent condition, and I was told that they are safe and reliable as long as I do not exceed 1 bar of boost.
Thanks very much for your input! It is much appreciated! :blink:
Excellent condition or not means nothing. Simply because you cannot truly tell without pulling it apart.
They are 15-20yr old turbos in most cases.
I would be backing off to 10psi with a built motor to be honest mate. You'll have better odd's in a casino, as they are not reliable at all when getting old and running 1bar.
I'd only run 1bar on low km R34 GTR items on a built motor, and even then i wouldn't sleep easy @ night knowing the trouble just one full throttle squirt can cause.
I'm not trying to scaremonger you here either, i just hate seeing people loose big engines for silly things.
Roger that. Will take it on board.
Anybody else have any other opinions on the acceleration/stalling issue I'm experiencing?
Until you swap out the AFM's with a known working set - its going to be a bit hard for any further advice from most corners as its almost pointing soley to one or both AFM's intermittently playing up.
Could be as simple as an electrical short in the AFM wire and plug..
Try playing with the AFM wire and plug while idling... Any consistant changes in idle or cutting off would indicate a short
Edited by shinaka
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
