Hi all,
the Wife generously came to pick me up from the station last night and when we got ready to head home tadaaaa... nothing....
All lights work, connections checked and cleaned, jump started, disconnected the ECU and re-connected, checked all connections to SAFC, banged the alternator, check fuses in engine bay and inside......
turn the key and accessories light up normally but there is no clicking over..... like there’s no power to the starter or something.... checked that too.
I’m completely stumped....
the car has been driving perfectly for ages and just yesterday my wife drive it on many short distance trips without issues....
this happened once before when I initially installed the SAFC and SITC but then when the ecu was disconnected and reconnected it was fine ....
it sux as its our only car ATM.......
any thoughts or other checks i can do???
thanks in advance
Ian
https://www.sau.com.au/forums/topic/287337-s1-not-starting-at-all/
you say you bashed the alternator, did you think to tap the starter motor??
can you hear a 'click' when you turn the key?? if not, its probably the solenoid on the starter. if you can, its more than likely the starter itself........
actually thats a good point! if it WAS automatic, and its now manual (for whatever reason) then the starter inhibitor might be faulty. as in the wire bridging what used to be a switch, is now not working
Thanks for the reply... probably should have mentioned that i did hit the starter.....Not had :)
there is no click when the key is turned.....
long shot but in knocked off the solinoid wire to my starter motor.. same symtoms as u said... check that, is there any way to test if its getting power easy???
it was all in place but i have to admit i probably could have paid more attention to that... will do so tonight.
i just dont get how it just died after been turned off for less than 10 minutes.....
maybe try using a jumper lead from the positive battery terminal to the positive terminal of the starter, see if it kicks over.......
if you can hear a click, its either a wiring issue, or your starter is shagged. and yes they can just stop working!
Unless you have a quality surge protector fitted, I would not recommend doing this one. I have seen the ECU in a commonwhore go up in smoke trying this jobbie. Not saying it WILL happen, but there is a risk.
Make sure it is not in "D"rive when you turn the key?
Double checked that.
i had though about it but wasnt game enough
Damn: the flux capacitor requires 1.21GW of power to function... just get some plutonium...
...Or fit a Mr. Fusion
LOL
well i got it started....
didnt do anything really.... jiggled the loom at ecu and gave the starter another tap....
drove it and got back home switched the car off turned it back on and let it run for a bit and then off again....
then suprise it wouldnt start again..... did exactly what i did before (loom and starter) nothing
F*$K
My R31 did something very similar.
Would start when cold, but would not when warm (just after a drive or in the warmer months).
I used to get it started by shorting out the starter motor with a long screwdriver.
Worked every time.
My old R31 used to do this randomly, (had the hitachi starter not the bosch) turned out when I stripped the starter, one brush (out of four) was worn more than the others, and would occasionally juuust not be in contact with the comm.
Would start perfectly 50 times, then not, start perfectly for ages then not. Was a major pain, couldn't let my g/f drive it cos it might strand her. Four new brushes (I just took the brush holder to an auto elec, as the leads are soldered in place, didn't have a big enough soldering iron) $45 later, problem solved.
Chased this issue for at least 4 months, was ready to burn it... Good luck.
Well i have been doing the screwdriver thing all weekend..... so its definately starter solenoid.
Some random dude helped out the wife on friday and say it was "the starter solenoid valve".
Same boat
so anyone had to relpace a solenoid before??? same as R33 i would assume??
hard to get at your local supercrap or repco??
Apologies for the questions above… was a bit lazy should have assumed the starter was the same across the RB series.
Well yesterday I though id attack the starter and try to fix the solenoid…. One of the most traumatic experiences ever….
Man it’s a pain to even get the starter off….
Anyway I got the solenoid off and have all contact points a clean and re-soldered it…. Took about 2.5 hours to get it back on but it works now…..
Haven’t had an issue yet …… let’s hope it stays that way
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
