i have just installed a new alpine head unit in my R33 s2. the head unit works alright, but the clock on the dash seems to be resetting itself every time when i start my car. even my head unit pushes the cd out and is in off-mode every time i restart my car. the previous head unit was also an alpine. did i do something wrong with the installation? help needed.
I'm guessing there is a "memory wire" (+) that should connect straight to the battery and not via the ignition...
usually yellow wire
i bet you connected memory (yellow) to power (red )
what headunit you have?
i had an alpine unit previously. so i bought a new alpine unit and connected the exact same wires to the new unit. yellow to yellow, etc. what should i do now?
  • 5 months later...
i know its a late post but im having the same dramas, but i know what the problem is but cant the the bloody fuse for the back up, where is it??? am i missing something, in my car tho everything resets, air con, clock, cd player
  • 3 weeks later...
pull them till you find a blown one. I can't remember placement in that panel.
i did this like 2 or 3 times, thats y im confused cause i cant find a blown fuse anywhere, i must be missing something, its driving me nuts
Get a cable tester (little sharp point thing with the little light in it) and start going through your dash with the ignition off and find your constant power & ignition power cables and make sure you've wired up the head unit properly.
If it's affecting aircon, stereo & clock, then it would have to be a fuse.
