  • Replies 57
Price drop 4K eh????
That mean your now looking for about $8000.00 now?????????
mmmmmmmmmmmmmmm, I think you should take the 2K offer because that's about what it's worth.
The condition of the paint work makes it a BARE METAL RESPRAY and they are expensive, if it's going to be brought back to it's former self. 5K Plus for this, not to mention the replacement cost of the necessary panels & the lower front skirt which is only available ex Japan.
I purchased my Paul Newman version coupe for $5000.00 and it is in very near perfect condition and many streets & blocks ahead of this car you're trying to sell. I also bought a genuine DR30 coupe in lots better condition than yours for $3400.00, so I still say your dreaming thinking of anything near the figure you expect.
I also know of the 2 other Paul Newman cars in Oz & I could buy both of them for less than $8000.00 each and they need absolutely ZERO work to be done to them, as they are now in excellent condition and what's more "THEY ARE RARE".
Don't listen to MAG86, he's just blowing wind up your ass, import or not, your car needs a LOT of TLC and other than the L20ET motor, it's just another R30 sedan which are a dime a dozen.
You might be well advised to take any offer around $2000.00 before you're calling SIMS to come and take it away for free.
Cheers, D
the price is $4k total.... much more money has been spent on this car and the only thing it needs is a paint job. - so if you spend $3-4k on paint you'd have an exceptional car for less than $10k
Note to Ghostrider: F off you old tool! you got a good deal on your paul newman and that would have probably been around the same time i bought mine nearly 8 years ago so get over your self.....
no RWC
but i can tell you what it would need...
washer bottle for wipers (i took it out when i move the air filter but still have the water pump/motor and hoses)
remote swich for the horn (the boss kit for the wheel doesn't meet the brass pin for the horn)
rear demister switch (it burnt out)
new fuse for the hazard lights (burnt out the other week i think)
don't have the time to run around to wreckers to grab those things at the moment but all would be easy to find and put in yourself
Just a question and a free bump... Your gallery pics include:
pretty much original except for whelding up the stock bleed value and putting a damn loud blitz BOV on
Can it get a roadworthy with welded bleed valve, BOV and pod filter?
cheers,
JH
cheers,
JH
factory bleed valve was faulty and would have cracked the mainfold to remove and refit a new one and the air filter is semi inclosed and can easily be turned into a full contained box if need be
if i got a RWC would you consider making an offer..
car is obviously fully complied, and has current registration in vic. When i changed over the plates from QLD to VIC all vic roads wanted was the chassis/vin numbers and the rego was simply changed over.
not sure what the rules are in vic but i would have thought someone could just have the rego and ownership changed into their name and all would be apples.
Dave
Dave
Hi Dave,
There are two ways to change ownership..
1. Transfer the rego and ownership with a valid RWC. The RWC has to be done by a licensed tester. Sometimes the seller pays for the RWC or the buyer might agree to pay for it.
2. You hand in the plates (and maybe get a refund on part of the reg) and sell it unregistered. The new owner has to then get the car re-registered which requires an inspection. Not sure if Vic Roads has to see the car or if they'll accept a RWC.
cheers,
JohnH
Hi Dave,
cheers,
JohnH
an inspection was needed if i didn't have the vin/chassis number handy. It was thought to have the FJ20 motor in it due to a f**k up when it was originally imported... It was thought that a 2.0 badge on the boot meant FJ not L20 so you may be able to slide an FJ in there with minimal hassles.. The original owner in Brisbane who imported tried to have it changed but no joy and back then four bangers were cheaper to rego so he gave up... Same thing happened to me when i first had it insured it was on Shannons books as an FJ same as rego and no one wanted to change it so meh...
I'm sure i'll be able to get my hands on an RWC if you'd like that easy of mind for a rego/ownership transfer
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
