I have a 1983 R30 Nissan Skyline in good condition, but needs a new clutch. It still has the original clutch and I was thinking of putting a better one in. What do you recommend? Also I was thinking about doing up the car. Is is possible to put a turbo in one of these and how much? What else would be a useful upgrade? Thanks.
https://www.sau.com.au/forums/topic/28736-new-clutch-for-1983-nissan-skyline/
yeh you can get heavy duty clutches for them i have one in my R30.
Over all its not worth the hastle to try turboing your L24E it would be far more practical just to put a good 2 1/2" exhaust, maybe some extractors, change the air intake (ie cut hole in top of air box or modify to fit pod filter) then have the mixtures adjusted on the AFM by a professional. will be a fun car the 6 cylinder L series sound awesome with an exhaust.
i had all this and alot more to my R30 including worked L28E
MIKE CASH
When you did this conversion, did you have to do anything with the clutch master cylinder position, or did it stay where it was etc.
I am in the process of building an HR30 Paul Newman with similar, only going to RB30/25 hybrid DET.
As for clutch upgrades, the choice is endless depending on the money you want to spend. I am using a flywheel from Castlemaine Rod Shop, designed to use the 10.5 inch VL Turbo clutch. The cover has been made with over 1000kg full load and the drive plate Kevlar faced. Considering the standard MR30 clutch is only 8.8 inchs and 450kg full load, it makes a very tidy upgrade. As it is untested at present, I think it will be better than any paddle clutch used on the street today and comparable to twin & maybe triple plate clutches and a stack of dollars cheaper.
As for original question, re turbo, I have an MR30 Ti Hatch with L24ET, the turbo was the standard T025 off the HR30 and it keeps up with any stock REX, it handles better than most rex's due to my suspension mods. The parts are relatively easy to get, they are all BOLT ON from the L20ET motor. If your serious, I might know where there is all the bits you need, in Sydney. I am soon to try a GT17 on it, as the GT17 is ball bearing, it is about the same size, but should spool up a lot faster reducing the lag to nearly nil.
I don't have much time for the L28 engine because after looking at the specs, it only has an extra 10HP over the L24E motor, I don't think the cost factor is worth the change. The MR30 L24E has 93.4 Kw (125HP) the L28 from 280ZX has 135HP. With the mods suggested by Phat R30 your L24ET would probably blow away a stock rex. NOW! wouldn't that put a few noses out of joint.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
