Don't know ........................... let me get them first, but there costing AU$450 + freight out of Japan.
Cheers, D
It would want to come with some very happy endings for that price!
I'd put my name up for a set if they were getting around
I have some bigger flares I bought from Japan for mine; this size
If anyone is interested, Id let them go at the right price.
Steve
They look like chopped 'Type-1' ZG flares to me...
(i.e as fitted to the HS30H 240ZG)
  • 3 weeks later...
good luck with your overly priced bits of plastic Ghost
Dave,
I thought you were intelligent, but I guess you were standing behind the door when it was being handed out eh?
As I have said before, I need to get them before I can evaluate them, but I would assume they would be of some reasonable quality, because Jenesis doesn't sell junk. And to Birth, it wouldn't matter what they were made of, but there has to be something to make a mould from and not just be GP versions that need a lot of bog & putty to smooth them so they look the part and if they are so easy to copy, how come someone hasn't done it already.
Go for it, take your shots at anything I have put up, but just keep in mind Dave, your trying to sell a car that looks like it's $200.00 for $4000.00? PRESENTATION is just about EVERYTHING and you're presenting a sh!tbox and a POVERTY PACK at that.
Cheers, D
Dave,
Cheers, D
I'm sorry ghost, i didn't mean to offend and i do appreciate you concern when it come to the sale of my 'poverty' pack... i am glad your thoughts are with me and i hope not all your judgements are based on first sight..
best of luck mate and say hi to the misses.
Hi Ghostrider; I think you misunderstood me. What I was thinking is that if you bought the original units you could copy them yourself or pay someone like a fibreglass kit place to copy them for you. You could then go on to sell them for say half the price. Depending on what they cost to copy you could probably cover the cost of the initial purchase ($450-odd) and the cost of replicating them.
Come to think about it, if all four that you are buying are the same you could buy just one ($150'ish) and have thay one copied four times making it cheaper for you. Then any more that you have copied and sold would be profit.
I don't care about how much they are costing you etc. and hope that you don't get upset. I do reckon that this is a way to get you want you want for cheaper and make similar units available to others who think that what you are doing is flash (assuming that you don't mind other people having the same kit as you!)
Hi Ben
I think you'll find that copying one flare wouldn't do
Front and rear are different to suit the bodywork plus then possibly handed right and left.
Dennis provided he doesn't mind others having similar flares has the right to charge enough to cover his outlay and time IMHO.
Edited by R34
Exactly the plan!
Gotta start somewhere & all the flares I have seen have been grafted to suit with buckets of bog. These should be a fit up thing I'm hoping? And the R30 has a squareish rear wheel arch as opposed to the Z types that are nearly round.
Cheers, D
    • Good points thanks. Unfortunately I can't seem to rename this or delete the topic. Seems like I'll ask the moderators to change it or delete it.
    • You might want to update the thread title.  V37 ≠ V36.  And it probably isn't a G37 unless it is 2012+ Ininiti or LHD.
    • Just a basic run down of the relevant bolt-ons. All e85 First graph 406.9whp is HKS GT-RS, HPI manifold, 3" bell mouth dump / 3" straight through fake cat / 3" all the way to the rear and no resonators, nismo 740cc, walbro 460, oem RB26 itb's, power fc, eboost2, Greddy Spec M fmic, poncams, Turbosmart actuator, splitfires, ARD 150amp alternator. Blue line is same as above but Blitz Dual SBC (before i upgraded to eboost2) and 100cell "high flow" cat. Red line is after installing eboost2 and the fake 3" cat (it's just a 3" pipe with a cat shell welded onto it). Huge gains in response, as can be seen. Black dots are a mates sr20 with almost identical setup but uses a garrett 2871 instead oh HKS. Next grapghn 466.6whp is same as above, but HKS 2835 Pro S with the larger .87ar turbine housing, the special HKS Pro S dump pipe into a HPI split dual 2.5" front pipe and the rest stayed as is. Red line is after I welded the actuator brackets. (It was originally bolted together and was moving a couple millimetres under load). Green line is obviously before I welded the bracket, no other changes. 100whp gain at 3750rpm, massive gain for such a simple fix. Third graph is my current setup, huge changes. 469.7whp R31house twin scroll manifold, twin TiAl 38mm gates, Forced Performance (USA) HTA3076 with 1.01ar twin scroll rear housing, Link Fury+ and loom by 12volt, PRP trigger kit and r35 coil kit with r35 splitfire coils, HKS step 1 vct staggered cams, new oem lifters and performance springs, 49mm itb's w/port matched Nismo plenum, twin walbro 460 surge tank setup + 1650cc injectors, HKS Type R S13 600x300x103mm fmic, individual egt's, 4" turbo back with no resonators or cat and AES true straight through muffler + 4" butterfly off the dump pipe lower 90° bend. It's a preliminary tune with no boost control with using 20psi gate springs and 4" butterfly closed. Once body loom and PDM is compete, will go for 30psi tune.
    • Power light apparently functions as a transmission error light, you can try the power sequence to read any codes from the transmission control unit.
