My parker light isnt wokin, and i want to change it, prob change both of em but unsure how to get to it
The head lights are easy to get too, just the parkers. Do i need to remove the whole light assembly, it
looks quite tight in there :thanks:
front parkers? lie on your back and stick your head under the front bar and push and twist, and the fitting should come out, do it from the back or rear of the housing, but I have a '98 and they are slightly different.
From underneath? Indicators maybe but parkers? nooo.
Best way is to unbolt and move the coolant bottle, fusebox and washer bottle for the drivers.
Sounds alot, but seriously it will save you grief.
There is a little hole in the corner that has a plug. Give it a twist and it will undo. It needs to be a HARD twist as they jam a little. I found long nose pliers easiest.
Same on passenger side, but various other objects to navigate.
LOL i had a look underneath and thought , how the f*ck did he get to em from ere. But yeh just eded up doin what Yarp said , it is a hard twist to get em 'far out', hopefully they last cas not lookin forward to changen them again. my hands got hell cut up lol . thanks for ur help ppl :(:worship:
Yea I just changed mine cuz one blew, was so hard changing the drivers side one, done it without moving anything, hands were heaps sore after lol. hate cars made for tiny asian hands lol. jks.
i just ended up puttin in LEDs in , i just took the windscreen washer tank out , heaps easier. the old bulb was blown alright, the glass was smashed :D . all good now. the first time u do something is the hardest, so next time it will a piece of piss :D
are those LED coloured park lights illegal?...
i bought some green red and blue ones, been told red and blue are reserved for emergency lights but not sure about green, can anyone shed any light on this?
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
