180sx Stolen - Bright Orange - 1AWD129
MrSnrub
 Share
The Silvia guys are soon gonna look at a keypad immobilser group buy. basically (for those that dont know) its a 10 digit keypad where you have to put in a pin number to start the car. Good for when theives get your keys.
If SAUWA guys are interested maybe we can get some more buyers here.
Ooh ooh!! I am keen!
/me toddles off to SilviaWA forums..
saw an orange 180 today (sunday) on a tray top truck around 12 or later in beechboro on benara crossing tonkin.  same car?
Yes it was the same car, It was on its way back to the owners house. They trucked it beacuse they didnt know if there was any damage to the motor from it running out of water in the radiator.
Yeah your rite there dude, Dave and myslef are doing some work on his car today and sorting out how bad the motor acually is. I'll let him know that your willing to help, his on his way to my house now.
Yeh Josh i just spoke to him on phone. Just tell him to ring me when you's get to his house. I prolly got some tooks n shit he needs.
Thank god for that aye!!!
Im hella happy for you that you got it back :rofl:
Hope nothin like this happens again...
Such a nice car, Ill look out for you on da roads :rofl:
In my 91 Exa... haha :)
Again.. thank god for findin it!
Hope it dun cost u too much to fix it all up??
Jaz
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
