i got a pair Garrett group A ball bearing turbo FS,VGC,only use 20000km,rate are 700hp,price are $3000 it wil fit on R32/33/34GTR
a pair of extension(down pipes),same as hks,price $550----------sold
Got Trust T517Z turbo kits FS,come with trust manifold,VGC,$3300,fit S15 and all SR20DET
Apexi GT-SPEC full staniless steel cat back exhaust system for S15 $1100
located in QLD
https://www.sau.com.au/forums/topic/28739-gtr-and-s15-parts-fs/
helo MINES_DATSUN :
they are rate at 700hp,each turbo wil handle up to 350HP,its ball bearing turbo and the boost start around 3000rpm and full boost around 4000rpm,the max this turbo can handle is 1.7bar,i run 1.1bar on this turbo and make 352hp on 4WD dyno,which is very good,i got power FC and large fmic,
GTR R32 :
i havent got any pics.the down pipes are brand new and it got separte wasgate pipe,same as HKS down pipe
helo jmp:
the T517z kit come with turbo and manifold,(all trust,vgc)
psiko:
i havent got pics for the down pipes,its dual style,like separte wasgate pipes,
MINES_DATSUN :
its hard to compare this turbo to HKS GT2530,GT2530 are very good turbo and better for street,but group A turbo make more power than GT2530,it all depend on what u need.
  • 4 weeks later...
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
