I am considering purchasing an R32 GTR and was wondering where is the first place to start looking for extra horse power ?
Having owner WRX's in the past and having modified them somewhat I was anticpating increaseing boost levels.
What level of boost will the car take in standard trim ?
Additionally I would love to know what level of boost the car woud take when fitted with Aftermarket intercooler and exhaust ?
HELP !!!!!
https://www.sau.com.au/forums/topic/28742-mods-to-gtr-r32/
A good exhaust, filters,cam gears, 14psi and tune will get you around 220-240kws at the wheels depending on condition/age of engine.
No need for new cooler, the std cooler is good ebough even with upgraded turbos. Clutch may need attention though. Typically 14-15psi is what ppl ask of the std turbos, but age and maintenance history of car plays a part just as it does on any 2nd hand turbo car.
https://www.sau.com.au/forums/topic/28742-mods-to-gtr-r32/#findComment-593235
Cam sprockets (or Cam gears) attach to the front of the cams and allow the cams to be adjusted. Expect to pay around $250-$300 each for both intake and exhaust cam sprockets.
You can get 14-15 psi by removing the little boost restrictor olive in GTRs, cost =$0 and is incredibly easy to do.
https://www.sau.com.au/forums/topic/28742-mods-to-gtr-r32/#findComment-593549
Hey,
I bought a totally stock R32 GTR early this year and here's a few things I did with mine..
Dyno'd just after i bought it - 165kw's at all fours.
With HKS Front pipes, TRUST cat back exhaust system, Apexi pod filters and the $0 mod..removing the boost restrictor olive, running 13psi it made - 190kw's at all fours. Everything else standard :cheers:
Cheers
Jono
https://www.sau.com.au/forums/topic/28742-mods-to-gtr-r32/#findComment-593697
definately start with the exhaust and then get POD filters. run 1 bar through the turbo's and you should have a decent amount of power.
Personally I would do that, then cooler and an ECU and have it re-tuned to see what kind of power she makes.
I would be very interested in the motors capabilities with "breathe easier" mods if you know what I'm trying to say :cheers:
https://www.sau.com.au/forums/topic/28742-mods-to-gtr-r32/#findComment-593714
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
