Hey guys, just bought a R32 GTR, will post pics later
the 4wd and ABS light is on, all the time..
Hicas light is fine....
any ideas???
does that mean im runing on rear wheel drive all the time now or??
there is 2 ecu's underneath the speaks.. wch is wch??
anybody here had the same problem before, plz help me..
i havent went for diagnose, but im pretty sure my area does not have the correct socket for my car.. so i might have to do manually..
THANKS !!
https://www.sau.com.au/forums/topic/287424-need-help-4wd-and-abs-light-on/
Yer mate, that sounds like its running in 2wd. Ive got a torque split controller in my GTS4 and those lights come on when i flick the switch to 2wd.
I would check the fuse box under the bonnet as there is a fuse there that controls the ATTESA. If it is removed or blown the abs and 4wd will come on.
I also suggest checking the fluid level for the transfer case which is located in the rear boot, right hand side behind the panaling. there is a reservoir tank there. This can also make the light come on but i only had the 4wd light come on from that.
Only other thing i can think of is the G/Force sensor under center console having a problem but i dont think it is that.
Let me know how you go...
Pulling the AWD fuse will put it into 2WD mode and those to lights will appear. Previous owner might have pulled the fuse for 2WD and never put it back in.
With the ignition on (i cant remember if the engine needs to be running or not), underneath one of those computers in the boot, is the ATTESSA computer, you will know it because a redlight will be flashing code(s) underneath. Get back to us on the codes and we can help translate to what they're indicating.
Here's the incabin fusebox (under steering wheel) translated and the location of the 4WD fuse:
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 🥴
