Motor have run their annual tyre test, this year the results seem to be more relevant to us....they tested 18' performance tyres ;)
Tests were dry stopping, wet stopping and wet and dry lap times of a track at DECA.
Results:
DL - Dry Lap
DS - Dry Stop 100-0km/h
WL - Wet Lap
WS - Wet Stop 80-0km/h
Goodyear Eagle F1 WL 16.54s, WS 38.1m, DL 45.32s, DS 39.6m, Avg Price $462
Bridgestone Potenza Re040 WL 16.92s, WS 41.3m, DL 44.79s, DS 44.5m, Avg Price $413
Dunlop SP Sport 9000 WL 16.83s, WS 37.8m, DL 46.49, DS 46.1m, Avg Price $485
Pirelli P Zero Nero WL 17.02s, WS 34.7m, DL 46.09s, DS 42.7m, Avg Price $491
Falken GRB FK451 WL 17.21s, WS 32.4m, DL 45.36, DS 37.7m, Avg Price $383
Toyo Proxes T1-S WL 17.13s, WS 44m, DL 45.53s, DS 40.3m, Avg Price $411
Hankook Ventus Sport K104 WL 17.23s, WS 34.5m, DL 45.16s, DS 39.6m, Avg Price $333
Michelin Pilot Sport WL 17.32s, WS 38.8m, DL 44.83s, DS 43.2s, Avg Price $589
https://www.sau.com.au/forums/topic/28744-which-tyres-motor-magazine-test/
And which tire did they award the winner?
They didn't have a "winner" as such, but interestingly the second cheapest tyre, falken fk451, was best in both wet and dry braking tests.
The guys at motor seem to say you cant go past the Hankooks, which is a good thing since they are the cheapest tyre there.
That was how i read it. Being a tight ass and all :cheers:
Even though the website says they have a shitload of sizes in the k104 they only seem to have 18s and some 17s atm though.
Melb (dunno about other states) has a Goodyear tyre deal - buy 4 for the price of 3...
Picked up a set of Goodyear Eagle F1 GSD3 - $245/each x 3 + $40 4w align = $775.
These German made GSD3s are substantially better than the Thailand made GSD2 - with improvements made in all aspects of the tyre too!
Otherwise I probably would have settled for the cheaper Kuhmo 712s @ 190each but then would have to buy 4...
In Jan 2003 motor mag ran their annual tyre test on the top 13 performance tyres
1) Dunlop Formla FM901 cost $1150
2) Pirelli P Zero Nero cost $1320
3) Bridgestone Potenza S-03 cost $1180
4) Goodyear Eagle F1 GS-D3 cost $1516
5) Firestone SZ50 cost $884
6) Hankook Ventus K104 $688
7) Michelin Pilot Preceha $1350
8) BF Goodrich Profiler G $1140
9) Avon ZZ3 $940
10) Toyo Trampio GU:WN $892
11) Simex SM9300 $700
12) Kumho ECSTA Supra712 $780
13) Federal 589 $632
Fooey that list above is from the last test of which the Michelin Preceda's won. I have been using them for around 6mths and they are fantastic.
I guess i'll have to take a read of the latest Motor Mag during my lunch break on Monday to read over this latest set of tests.
Just got a set of Michelin Pilot sports on the car today;
235/40/18
265/35/18
still scrubbing them in, but they seem excellent under braking. they squeal a bit, but i think that is just the silicon coat of the new tyre wearing off
Don't know about the tests in the first post, as far as I can see they all lapped more than twice as fast in the wet as they did in the dry and they all stopped quicker in the wet than the dry, seems just a little odd???
The thing I find funny I've tried top line tyres and cheaper (use more for bunrouts ) lower range tyres and find the Falkens and slighlty cheaper ones to be crap in the wet. Mind you I have to say, rear tyres don't last but my question why 80-0km/h in the wet test and not a 100-0km/h test. ?
Me thinks the collumns got shifted in the translation. I had Bridgestone Potenzas on my SSS which I liked. Choice magazine did a test that included them and hey actually had the same stopping distance in the wet and the dry and in the dry they were I think 2nd best.
haha, I think I got the columns the right way around? The wet and dry tracks were different, wet was much shorter from memory. And the dry braking test was from 100, the wet from 80 :D
My last set of tyres were the Yokihama 539's. I thought they were great, really progressive at and beyond the limit of traction without any nasty characteristics. I also measured 1g cornering with an accelerometer around the big round about at the end of Centenary highway and Ipswich Rd.
I've now upped the anti with a set of Bridgestone R compound RE540S, now they have grip. Reduced my lap times by over 2secs.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
