Does anyone out there no where i might find that anoying little wire that limits my speeding i drive a 1990 R32 GTS-T type M. Also want to no if it has a "speed Signal" wire so i can hook up one of those Greddy Full Auto timers, wiring diagrams are hard to find round here! :headspin:
http://www.powerlink.co.nz/~graeme/faq/
https://www.sau.com.au/forums/topic/28746-cut-out-speed-cut/#findComment-593247
yeah man there is a wire you can cut to get rid of the speed limiter cant remember which one, do a search.
i installed one of the greddy full auto timers afew weeks ago the wire you need is a (yellow/green, i think, check the pin out diagram for your ecu) that is on the bottom half of the ecu pin outs.
They are a great timer i am very happy with mine.
https://www.sau.com.au/forums/topic/28746-cut-out-speed-cut/#findComment-594386
Is it as simple as cutting the wire only?
I have an R33 but can't imagine it would be that different.
Anyway, installed an APEXi RevSpeed meter last week.
When cuttiung out the speed delimiter, we cut a wire and fed it into the Apexi thing, then an output was fed back into the ECU.
So although it was cut, the signal was not lost, just altered I guess before hitting the ECU.
Awesome little thing to have buy the way considering my speedo is crapped out. Probably from winding back etc, so this little ripper did 2 things for, speedo and delimiter ! I lurv it :D
https://www.sau.com.au/forums/topic/28746-cut-out-speed-cut/#findComment-594838
