Theres something in my airbag steering wheel that sounds like its swinging around.
When moved either left or right it 'clocks' around, and sounds like metal hitting metal.
Its progressively gotten louder, so somethings probably coming loose.
Something else that cant be a coincidence. Last weekend my horn would go off whenever I turned the wheel, I had to pull the fuse, maybe the loose part is shorting something?
Anyway I'll be getting it checked next week, anyone got any ideas on what the mysterious noise would be? I hope it hasn't damaged the airbag.
Steering Wheel.
https://www.sau.com.au/forums/topic/28750-something-loose-in-steering-wheel/
When I first got my Skyline, the horn button was acting up and there were some funny noises in there. Mine is a non airbag model.
When I pulled the cover off the wheel, I discovered that the plastic insert for the centre of of the steering wheel was in about 4 pieces... I reckon the last jap driver was a cranky man and used to bash on the horn ;)
I just reassembled the part with some Araldite and had forgotten about it until now...
HTH
Thats funny, sometime last year i got really pissed off and hit the wheel alittle too hard.. Try 20 pieces! So i did the dodgy and removed the plastic bits and filled up the space with double-sided tape.. Makes beeping the horn as spongy as a pillow!
I do intend on fixing this............ ;)
The broken horn thing on these cars is a very common problem. I keep having to remind myself when I want to bash the horn button after some bastard cuts me off!
Its getting sorted tomorrow, dunno what it is yet though.
I've never wanted beep so many dickheads, as I have in last week!
Steering Wheel.
There is a vibration absorber in the steering wheel which is suspended between rubber buttons. Sounds like the rubbers have broken. You can fix it with silicon rubber tubing.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
    • Well found out it’s a 60th anniversary gtst from that it came with 205-55r15
