Installed My Swaybars Today
Yo
Did my swaybars today, can I just say what a MAJOR difference the car feels to drive now, feels just like my old 350z now to drive handling wise which is a good thing :P
I've never had the pleasure of driving one, but if the V35's are anything like the 36 then they must suffer a bad case of understeer?
If you've been thinking about them but holding off I definitely think they're a worthwhile upgrade
corners that I used to have to fight the steering wheel (under under!) to get around are now taken with ease, the car feels precise and stable, where I used to make minor steering corrections mid corner/roundabout and the wavy boat feeling has disappeared.
I have noticed the car feels harsher when entering/exiting driveways and speedhumps but I'm not complaining
I wish these had arrived in time for the texikhana that just passed, no joke I would've done a whole lot better than I did on the day :)
just thought I'd share some pics, eibach lowering springs go in tomorrow!
fresh of the boat
plastic undertray had to be taken out
is there anything WD40 CAN'T do?
the difference between understeer and fun
this little bastard cost me nearly an hour :)
time to hit it from the back
had to unbolt the exhaust to get the bar out
side by side
tighten everything back up an voila
more pics to come after the springs are in >_<
wow....well done Yo! looks crazy man... just a quick ?. did you buy rear camber kit aswell?
hey, I was going to depending how the springs went and alignment after installing everything, thankfully they were able to get everything into spec without needing a camber kit :)
nice!!!
mind telling how much those set you back and where to order them from??
Hey mate I had to source them from the US, set me back $320 for the pair and shipping was almost as much as the bars themselves :P but money worth spending considering the end results transformed the car completely for the better
looks good , what size sway bars?
don't have a clue to be honest, they say it stiffens up the rear by 30-60% depending on the setting you choose
+10!!! haha
i've got my nismo swaybars installed as soon as i got my car! very worthwhile upgrade!
I know aye, wish they arrived sooner lol
Okay springs done today, decided to get them done by professionals, don't have the skills or the tools to tackle a spring install
big thanks to Wholesale suspension in Penrith for the install and Pat for fishing my stock springs back for me after I left :)
springs need some more time to settle so they're still due to dip a bit more
before
after
before
after
lowering looks hot too , how does it handle now?
i guess only time will tell if there's any camber wear, is anything fallible to correct this for v35/v36
yeah adjustable camber kits are available for those who are absolutely anal about tyre wear, but the shop that did my springs were able to get camber back in line at the front and about -1.4 neg. camber at the back = happy sideways times
Nice drop! I'm glad you didn't paint your wheels black like you intended to ...they look good as it is.
hehe, who said that? :) :) cheers buddy
the springs were a good choice, I tried driving around a shopping centre with notoriously high speed humps and I only scraped on one, and even then it was only the black plastic lip/splashguard under the car, this may change once the springs settle though so I'm hoping they don't drop too much more
Sup SKy,
what does WSP specialise in service?
WSP is a one stop shop for your suspension needs. They sell products but they also have a 6 hoist fitting and service area.
They build suspension parts to cater to all vehicles.
If anyone is interested in upgrades or full alignments i would suggest attending their open night on the 23rd Wednesday night 7pm
Free BBQ and lots of man talk!
Ill be there with the R33 :)
Yep pat helped me out :bunny:
I was impressed with wholesale suspension's setup, I used to drive past that place everyday to get to work but never been until now
I've toyed with the idea of spacers but I'm suss on using them even the hubcentric ones that also use their own bolts, but that's just me I guess... aren't they a defect?
don't really want to buy aftermarket rims, doesn't suit what I want from the car
cheers
cheers, the springs are eibach pro
I may still paint the wheels black, they are stained from when the dealer washed the rims after using tyre shine so there's black streaks stained into the rims that I can't wash out I'll either paint them black or shadow chrome
 Share
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
