i want to upgrade from my stock turbo, and my budget wont alow me to go all out at this point in time, so im thinking of hiflowing the stock rb20 turbo. i was thinking of throwing on a 33 turbo, but i think a hi flow 32 turbo would be more fun. anyone running a hiflow 32 turbo with any advice/ dyno graphs? cheers adam
https://www.sau.com.au/forums/topic/287541-hi-flow-stock-rb20-turbo/
hiflowing will set you back $1500~?
You can pick up a HKS2530 turbo for that price which will make 230kw atw w/ supporting mods.
The hiflow rb20 turbo would probably just hit 200kw atw i reckon
doesnt hypergear do rb20 hi flows for around $800?
would there be much difference in power/ response between hiflow 32 and stock s2 33 turb?
ah $800 ey not bad. Although a rb25 turbo sells for around $200~
for $800 you can import a hks2530 from japan
When i was looking back at getting a hiflow rb20 (at one point I had one but didnt fit on car) I was told it could make 210kw atw, whereas a rb25 turbo on a rb20 would make around 180-190kw but I couldnt find any evidence to back up the rb20 hiflow results.
I guess ask hypergear themselves how much power it can make and if its larger than a rb25 or is it smaller?
Let us know what you decide on.
$800 is bush bearing, not ball bearing.
Ball would be around $1500.
RB20's benefit the most from decent turbos - So if you are really dead set... spend as much there as possible, get a HKS2530 if you want the best suited
[/quote
thats what im trying to find out. there is plenty of dyno results on the rb20 upgrade sticky about rb25 turb, but almost nothing on rb20 hiflow. i know it will be a few hundred $$ cheaper to get a 33 turb, but it will be a second hand turbo, quite possibly ready to f**k out on me. im not really after any specific number of rwkw, just a nice basic upgrade. i would imagine tho that 180-190 would be a realistic target, but a good tune is more important to me. i will let you know rekin. cheers adam
are 2530's BB? what hp are they rated to? are they a direct bolt-on to rb20 manifold? thanks nismoid
220-240 rwkw seems to be about the ball park for one, depends on supporting mods tho. Will bolt on to the RB manifold so long its a T3 flanged one.
personally i'd go a HKS GTRS over a 2530 but they are a little more exxy again
gtrs would be great, but the car is 17 years old. i dont want a track beast, i dont want some wank-off dyno number, ive spent the money on supporting mods, now i want a very basic turb upgrade.
The hks2530 is ball bearing, not sure on power rating. Will direct bolt on manifold, dump pipe another story...
HKS2530 came out in 2 models. Series 1 and Series 2.
Series 1;
- Has a unique flange and needs the matching HKS cast dump pipe to be able to fit onto car
- Has more fins on wheel
- No split between wheel/wasteage
Series 2;
- Has a T3 flange which direct bolts to rb20 dump pipe
- Has 9 fins on wheel which has been redesigned to be more responsive
- Has a split between wheel and wastegate as opposed to the series 1 hks2530
Im running Hi flowed Rb20 turbo, getting 222kw with 104 octane fuel (which cost an arm and a leg)
with
444inj
040 pump
jjr coil packs
3'' front dump
fmic
apexi ecu and boost control
z32 afm
Im looking at putting something else on so I can get 230-240kws
dont know what these would be like
http://cgi.ebay.com.au/R32-R33-R34-RB25DET...id=p3286.c0.m14
how much does the 2530 go for brand new, compared to the GTRS.
is the GTRS also a direct bolt on like the 2530?
thanks.
with
444inj
040 pump
jjr coil packs
3'' front dump
fmic
z32 afm
what sort of boost do u run? how much was the hiflow if u dont mind me asking?
thanks.
2530 kit will cost u around 3k (imported, plus shipping) brand new, or more if u buy locally , i got quoted 3.5k from a HKS dealer in perth
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
