hey guys,
Bout to order some mods online....
I am choosing between the following 2 combinations: 1. Motordyne plenum + z-tube or 2. Motordyne plenum + z-tube+ jwt pop charger.
I've got an 5AT, which I consider a 'cruiser' rather than a 'muscle' car. Does anybody think the JWT pop charger could be too loud? Ive already got a fujitsubo exhaust which makes some decent sound at high rpm.
Also will excluding the pop charger mean I will get less overall power gains? Ive read the plenum/ztube/jwt can add 15kw to the wheels...
I just want to ensure my car keeps its character I guess...
cheers,
Danny
https://www.sau.com.au/forums/topic/287579-jwt-pop-charger-or-not/
I found my Popcharger only made my Z33 louder past like 3000RPM. Around town, you shouldn't even notice it.
Up in the rev range it gives the engine one hell of a nice note. I got compliments from everyone I drove past at WOT.
hey guys,
cheers,
Danny
Hmmm been meaning to get one myself. Where are u planning to buy it from? I saw one on Ebay US but the postage price puts me off.
hi,
Just wondering what power gains did u get? I heard in some cases there is a loss of power down low?
Not sure...
share your experiences
hi,
Not sure...
Come on Danny i know you have done you research :) Just buy that Space and get that Intake. +15rwkw is yours for the taking :)
Paul I sure I have ; )
I was referring to the Fujita filter..
no doubt the jwt/ztube combo adds some some power.
my only concern is if the sound is 2 loud, but seems like under 3000 I should be ok.
cant wait for the extra 15kw....
because the stillen are popular as well as the JWT and also help prevent with loss of power from heatsoak. The fujita and jwt will cause you to some power loss due to heatsoak without proper heatshield.
So far from my knowledge and the G35driver.com, that JWT are more popular for the 350z owner due to the hole intake at the front of the beam, while the V35 not as good. G35 in USA seems alot more popular using the stillen, being the one that having a good heatshield and prevention of heatloss. Also help with the problem of getting defect by cops too.
This is purely owners choice, if you just want sound then JWT pop charger. if you want sound and less chance of power loss, then go for stillen.
I just want the OEM looks and don't want trouble from coppers as well or even upgrade to the 06+ rev up intake box.
cheers
Edited by pw350gt
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
