This is my car, the question marks are things i'm not certain about because my mechanic has organised it not me.
Car: 1993 R33 GTS-t
Under the hood:
Engine: RB30det (RB30/25)
Internals: RB30 polished and balanced crank, Eagle Rods, HKS? pistons, Tomei Cams with adjustable cam gears, RB25 port and polished head, ? valve springs, Trust GReddy Plenum, ? Metal Gasket, Custom extractors and exhaust manifold. See through timing belt cover, N1 oil pump, and nismo water pump.
Induction: GT35/40 roller bearing turbine, with custom blade angles to spool up at 3000rpm, nürburg spec intercooler, Internal wastegate ?mm, custom airbox and pod filter to look as stock.
Fuel System: 1000cc injectors, GReddy fuel Rail, surge tank, Bosch fuel pump, braided lines, splitfire coil packs.
Management: Apexi power FC with hand controller.
Exhaust: 3.5 inch straight through and 9.5? inch cannon.
Gearbox: Rebuilt RB25 gearbox with strengthened 1st and 2nd gears.
Clutch: Exeedy twin plate with push button.
Diff: R200 2 way diff?
Brakes: R33 GTR calliper kit with drilled and slotted rotors.
Suspension:?
Wheels: 19x8.5 inch decorsa all round, running michilin sports pilot.
Performance estimate: 410rwkw, 900Nm, power to weight of 0.304kw/kg.
Now i've aimed for 400+rwkw, with the above modifications, should this be attainable, and if not, what should i look at doing.
The head has stage 1 cams and will be able to rev to 8,500rpm with the oil pump, water pump and nitrated crank.
the gt35/40 i heard is perfect for the engine, and the early spool should make it pretty awesome, i've read about a r31 called hypogt getting 480rwkw bt he had a 45mm external wastegate and smaller injectors, will the limitation of the internal wastegate, be an Achilles heal? I'm trying to make this look stock, so as far as a cop is concerned my mods will be exhaust and intake plenum.
the turbo will be low mount and in a bag and the pod filter in a box that looks like standard so this should pass the canary cops.
I am unsure what to think as i am a first year mechanic apprentice and many class members have said i'll be lucky to get 350rwkw, have they underestimated the RB30det or have i over estimated?
https://www.sau.com.au/forums/topic/287584-power-estimate/
Just wondering, if at all, you thought to take a read of the 400rwkw/GT35 thread already created in this section, that was the top post...
http://www.skylinesaustralia.com/forums/Re...5r-t287217.html
It answers pretty much all your questions which are well, the same. Please have a read of it. Especially the part about the exhaust size.
IMO you wont make 400rwkw internal gate.
Two other points.
1. 480rwkw through a GT35 - Not a chance. Even on C16 I'm dubious. It would have to be modified.
2. Being you are from Vic - i give you my word, if you are pulled over, you will not pass.
I was defected for a low mounted GT30, this was 5 years ago. Knowledge has spread far wider. This was factory everything else mostly.
You on the other hand have every other cop/EPA magnet parts - fuel rails, braided lines, and exhaust that is going to be so loud you'll be heard a block away.
If you think exhaust/plenum are the only "catch points" You are going to be in for a rude awakening.
Police are not as "dumb' as they were 6-7 years ago, I've noticed first hand a steady increase in awareness of all things modification.
If you get EPA'd, actually, don't even think about it... it's unspeakable badness for you.
If you want a legal 400rwkw - there are much better ways to do it and be MUCH more stealth, almost to the point of appearing 100% factory :)
https://www.sau.com.au/forums/topic/287584-power-estimate/#findComment-4821582
question isn't the legality issue, i have a few tricks for making it appear stock for that, the problem is, with my build am i dreaming to think i can get 410rwkw with a low mount internal wastegate setup like the 1 i listed, i read that post and got the rest of the info, i just want to know if it's possible, could i get more, or will i ultimately get less like my fellow apprentices believe.
https://www.sau.com.au/forums/topic/287584-power-estimate/#findComment-4821620
Well it around 650-700hp, so 350rwkw, perhaps a bit more.
Its really dependent on when the back pressure becomes a problem, you could look into having the rear ported a bit, dunno how much gain you'll see there though.
IMO put a 26/30 in there, -5's, look 100% factory/400rwkw/easily engineered.
https://www.sau.com.au/forums/topic/287584-power-estimate/#findComment-4821958
so how much is attainable with an internal wastegate?
Hey Hakon, where u from? Judging by your name it sounds like you're Norwegian, in that case you've got a neighbour here from Swede, building a RB30/26 :D
Good luck with the project!
Cheers!
https://www.sau.com.au/forums/topic/287584-power-estimate/#findComment-4834107
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
