hey guys Ive heard a few ideas thrown around about cold air intake and ive came up with a few ideas but would like to know everyone's opinion or other ideas on this? my r33 currently has a after market pod which I'm guessing would suck up a decent amount of heat, thus causing the cooler to work harder then it needs to.
1. I'm considering buying a stock air box whacking a k&n filter in and cutting a hole in the bottom and feeding some hose down low in the front which would get a nice flow of cold air.
2. leave the pod and buy/make a custom box to decease heat that gets to the filter and also run something to the front to feed the box with cold air.
also I'm new to the whole turbo scene and have been trying to hunt down a way that's best to set my boost controller so i know I'm not going to do damage to my turbo, im using a PRofec B-spec II which reads in percentage. Am i best to get someone to fiddle with it and monitor the boost guage while im driving and set it off the bar reading of my gauge
? if so does 8 psi for lo and 12 psi for hi sound good ?
thanks a lot for your help
    • Probably being in IT for 2 decades, and spending my time documenting trees worth of shit and also being on the receiving end has taught me a thing or two.
    • Why's that depressing, wouldn't it be able to go indefinitely until the battery gets old and craps itself? If it's constantly on charge/maintaining charge, won't that keep the battery healthy?
    • One of my concerns initially was if something catches fire somehow.
    • I think I know what you mean. I saw the same thing a while back, I think either the images on the website were wrong or the model was slightly updated. It was weird when I first looked at it, same model but different looking unit.
    • At work we've got a smaller version of the Projecta that Duncan posted above. At home, I have an ALDI trickle charger. Ive had it for about 8 years now. Only issue with it, it's a smart charger, so if the battery is dead, it won't bring it up, but I have a variable power supply that I limit current on, and set to a max of 14.4v. once it starts charging up, I put the aldi unit on and remove the variable PSU. ALDI one will do 12v, or 6v, then has mode for "car" "motorbike", and "snow". With car or motorbike more for its internal workings, and snow is the trickle mode. I have a battery in the garage that lives on this charger for about the last 18 months now on Snow mode. When I need to charge my other batteries (eg, ones that have died in a car), I get them started and then run it on car mode. Voltage is always sitting really nice, and hasn't killed a battery yet. that charger isn't good for things like Lithium batteries etc, I'd only use it on Lead Acid.
