Ok, here is the follow up to my USA-Spec install for a while ago.
The Spec.dock is an ipod/phone dock made specifically for the 35 and is only available only from 2point5.com in the US I will start by saying it ain't cheap, but you get what you pay for. I had originally planned to get something similar made locally but in the end this made the most sense. I just told them that i had a USA-Spec adapter and wanted to use with an iPhone 3G and they sent me over the suitable dock and connector.
So, very easy install, just need to drill a hole in the back of the ashtray, and route the cabling to wherever you have secured your converter box. Secure it down with the pre-atached double sided tape and its good to go. Few piccies below...
as it came out of the box. USA-Spec connector one end, dock on the other
centre console where the converter box lives
drilled out hole for the cable to pass through
dog getting sick of me taking ages... doing a good job guarding my bike though!
INSTALLED!
WORKING!
Sorry for poor quality pics, taken in the garage with poor lighting on my phone.
It charges and plays via line out. my only two small gripes are that the angle could be back a bit, its a little upright... and that it emits an extremely faint, high pitch noise, but with the engine on or even just music playing quietly its inaudible. So I can live with both of those quite happily.
Overall, very neat, extremely high quality build with integrated genuine apple dock, and accessible when needed. Highly recommended.
https://www.sau.com.au/forums/topic/287610-specdock/
I don't get it... what is being different with USA-Spec adapter? is it bose connectionn end, or apple in USA have different connector to Apple australia?
https://www.sau.com.au/forums/topic/287610-specdock/#findComment-4822264
nothing. to be honest I would like to grab that end as I dare say the controls are a Neo piece and it would work with the one i use here. would be even better if it spat out video as well.
https://www.sau.com.au/forums/topic/287610-specdock/#findComment-4822434
Hmmm. Obviously didn't explain well enough, this is just a replacement for the cable from the USA-Spec PAC-11NIS with a neatly integrated dock rather than the normal plug thing.
So whatever the normal PAC-11NIS unit does this does, but has somewhere to sit the phone and neatly hide away when you don't want it. Therefore, the steering wheel controls works as do the ones on the phone itself.
The key with all this is that the if you were to use the normal Apple plug and connect a normal Apple dock to it (which I tried) it doesn't work, because the dock routes the audio to the Line Out (designed to connect to stereos), rather than through the charge cable. I realise that this makes little sense, but I cant explain it any better. I also have no idea how Spec.dock do it, but it works!
I don't have the pop-up screen, so hooking into that isn't a consideration.
https://www.sau.com.au/forums/topic/287610-specdock/#findComment-4823079
Foo Fighters! Good choice of music :) Love that album too.
Have you tried driving around with the iphone docked? Does it fall off the dock on tight turns?
Because its an iphone specific dock it sits in really well. Wouldn't have it in there for targa west :bunny: but even hard road driving hasn't come close to dislodging it.
Something not designed for it though, like a Nano, could be a different story.
https://www.sau.com.au/forums/topic/287610-specdock/#findComment-4823088
  • 1 year later...
Hi Strydes
i am looking at ordering the same spec dock as you [no video] but with steering wheel controls
two questions did you need any extra cables or adptors for installation with the bose unit and how good does the iphone 3g handsfree work when recieving or making phone calls. :)
https://www.sau.com.au/forums/topic/287610-specdock/#findComment-5566584
Looks Sweet. I installed a spec.doc a few months back but opted for the video out version and I think that it is well worth the money. It would be good if you could get the steering wheel controls and video but it seems to be one or the other.
I put this vid on youtube for another member a few months back that might help a few people see what it does.
V35 DAS
Mine doesn't work for hands free. if the phone rings it fades out music, plays ringtone but then it reverts to the phone speaker and mic. You can put on speaker phone but then you have to shout as the Mic is in the bottom cradle.
hope that helps.
https://www.sau.com.au/forums/topic/287610-specdock/#findComment-5566779
ne need. BT control of the unit. did one about a week ago.
Sorry for my ignorance Chris whats a Bt Controll unit anyway gone off the idea of spec dock. iphone4 already needs different cradle looking at Parrot MKi9200
one question could the color TFT 2.4' be dislayed on the stock screen :(
https://www.sau.com.au/forums/topic/287610-specdock/#findComment-5569589
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
