Ok, here is the follow up to my USA-Spec install for a while ago.
The Spec.dock is an ipod/phone dock made specifically for the 35 and is only available only from 2point5.com in the US I will start by saying it ain't cheap, but you get what you pay for. I had originally planned to get something similar made locally but in the end this made the most sense. I just told them that i had a USA-Spec adapter and wanted to use with an iPhone 3G and they sent me over the suitable dock and connector.
So, very easy install, just need to drill a hole in the back of the ashtray, and route the cabling to wherever you have secured your converter box. Secure it down with the pre-atached double sided tape and its good to go. Few piccies below...
as it came out of the box. USA-Spec connector one end, dock on the other
centre console where the converter box lives
drilled out hole for the cable to pass through
dog getting sick of me taking ages... doing a good job guarding my bike though!
INSTALLED!
WORKING!
Sorry for poor quality pics, taken in the garage with poor lighting on my phone.
It charges and plays via line out. my only two small gripes are that the angle could be back a bit, its a little upright... and that it emits an extremely faint, high pitch noise, but with the engine on or even just music playing quietly its inaudible. So I can live with both of those quite happily.
Overall, very neat, extremely high quality build with integrated genuine apple dock, and accessible when needed. Highly recommended.
https://www.sau.com.au/forums/topic/287610-specdock/
I don't get it... what is being different with USA-Spec adapter? is it bose connectionn end, or apple in USA have different connector to Apple australia?
https://www.sau.com.au/forums/topic/287610-specdock/#findComment-4822264
nothing. to be honest I would like to grab that end as I dare say the controls are a Neo piece and it would work with the one i use here. would be even better if it spat out video as well.
https://www.sau.com.au/forums/topic/287610-specdock/#findComment-4822434
Hmmm. Obviously didn't explain well enough, this is just a replacement for the cable from the USA-Spec PAC-11NIS with a neatly integrated dock rather than the normal plug thing.
So whatever the normal PAC-11NIS unit does this does, but has somewhere to sit the phone and neatly hide away when you don't want it. Therefore, the steering wheel controls works as do the ones on the phone itself.
The key with all this is that the if you were to use the normal Apple plug and connect a normal Apple dock to it (which I tried) it doesn't work, because the dock routes the audio to the Line Out (designed to connect to stereos), rather than through the charge cable. I realise that this makes little sense, but I cant explain it any better. I also have no idea how Spec.dock do it, but it works!
I don't have the pop-up screen, so hooking into that isn't a consideration.
https://www.sau.com.au/forums/topic/287610-specdock/#findComment-4823079
Foo Fighters! Good choice of music :) Love that album too.
Have you tried driving around with the iphone docked? Does it fall off the dock on tight turns?
Because its an iphone specific dock it sits in really well. Wouldn't have it in there for targa west :bunny: but even hard road driving hasn't come close to dislodging it.
Something not designed for it though, like a Nano, could be a different story.
https://www.sau.com.au/forums/topic/287610-specdock/#findComment-4823088
  • 1 year later...
Hi Strydes
i am looking at ordering the same spec dock as you [no video] but with steering wheel controls
two questions did you need any extra cables or adptors for installation with the bose unit and how good does the iphone 3g handsfree work when recieving or making phone calls. :)
https://www.sau.com.au/forums/topic/287610-specdock/#findComment-5566584
Looks Sweet. I installed a spec.doc a few months back but opted for the video out version and I think that it is well worth the money. It would be good if you could get the steering wheel controls and video but it seems to be one or the other.
I put this vid on youtube for another member a few months back that might help a few people see what it does.
V35 DAS
Mine doesn't work for hands free. if the phone rings it fades out music, plays ringtone but then it reverts to the phone speaker and mic. You can put on speaker phone but then you have to shout as the Mic is in the bottom cradle.
hope that helps.
https://www.sau.com.au/forums/topic/287610-specdock/#findComment-5566779
ne need. BT control of the unit. did one about a week ago.
Sorry for my ignorance Chris whats a Bt Controll unit anyway gone off the idea of spec dock. iphone4 already needs different cradle looking at Parrot MKi9200
one question could the color TFT 2.4' be dislayed on the stock screen :(
https://www.sau.com.au/forums/topic/287610-specdock/#findComment-5569589
    • Is it possible to get your turbo high flowed that is capable of 270kw and cap it off at 220kw for example via a boost controller?
    • I will say most technicians aren't the best, then they see a Skyline and it seems like their brains start oozing out of their ears. But actual good techs that knew what they were doing to begin with I don't see them having any issues with this car. And it doesn't attract that much attention. But if you were wondering what it's like to be an attractive woman, driving an RHD Skyline in the US is pretty much as close as it gets in terms of endless male attention. Random people will strike up conversations with you at gas stations, at mechanics, etc. List goes on. When I do alignments for any car I never leave it overnight. I bring it in same day and usually just mill around outside the shop because I can't be bothered to call a taxi to go somewhere for 30 minutes only to get another taxi back.
    • By way of parts My local Nissan had a new water pump i needed👍. But i just had to buy and new AC compressor from the US 👎. Hit and miss with parts
    • Gas springs (ie boot/bonnet struts) will be charged up to about 200 bar. That's a bit scary. Suspension dampers will have maybe 10 bar of N2 pressure, which is just a sneeze, where I come from. Anyone drilling holes in anything, pressurised or not, without wearing safety glasses deserves swarf in the eyes.
    • 2 legitimate street and one carpark with some variety.
