  • Replies 203
Has anybody got a standard battery for an R34? Ive got electrical problems which i think is a f**ked battery, just wanted to see if somebody could lend me their battery to see if it fixes the problem? Can drive to you and try it out at your place, don't need to take it anywhere, just want to try out a standard R34 battery before i go buy a new one...
Tried connecting to another vehicle w/ jumper cables?
Nah, problems are things like my headlights and stereo turning off when i flick on my indicator, stereo turns off first time i put my foot on the brake after starting the car. Stereo always turns straight back on though. Its like there is a surge and things go into protection. There are problems with the car off too, like if i put my foot on the brake then the interior light goes really dim. And when i switch my car off the headlights instantly go out and all the other lights flicker and go dim. Voltmeter drops down to about 8
  • 1 month later...
  • 3 weeks later...
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
