Need asap a R33 s1/s1.5 stock front bumper for borrow or swap with my fibreglass GTR style one and a "sealed battery". <Battery would be just borrow for pits and thats it as I will put my current one back in.
PM me asap please if you can help.
  • Replies 203
I don't know. Mine is a low maintenance one which apparently won't suffice... Atm I'm going to go back saying the boot is sealed itself so there should be no problems... Plus they came from the factory like that =/
I need pit friendly ones.. My rear left failed right on the far inner edge which is super annoying cause the rest of the tyre is near new and not cheap (dunlop SP sport). I don't really want to change the rear pair just cause of that tiny inner edge..
  • 4 weeks later...
I have
4x legal stockies (2@ 75%, 2@ 60%)
2x legal 18" tyre/rims (90% -235's)
Stock manifold
2x adjustable front spare suspension
1x rear
2x spare rear rotors and brakes - need to be cleaned
And I think it's a series 2 diff? Definately not series 1
China style 3076r
If anyone needs to borrow them/ buy them for the pits, but I won't be home until the 18th of November.
All parts are for an r33 - south of the river
Cheers
Brenton
  • 3 weeks later...
  • 3 weeks later...
  • 3 weeks later...
  • 4 weeks later...
Just move to WA and have a couple R32 GTR bits and pieces that may be of interest to those in need:
set of std R32 GTR coilover suspension
I currently have x2 std catalytic convertors
A set of std front pipes
A set of std cam gears
Hope this helps
Does anyone have stock R34 GT-T wheels that I can borrow ? :rolleyes:
I have a set of wheels and tyres, I think they're Nissan Silvia (S14/S15) 16's with legal 205/55R16 or 225/50R16 tyres (not staggered) on some rims. Can't guarantee they will clear the GT-T calipers though.
  • 1 month later...
  • 3 weeks later...
Its been a while and I still have no luck in finding a stock exhaust not even by buying..
Can someone help me or point me out to who might have it?
Also I will always have
Stock RB25 BOV
Stock R34 GTT suspension (lowered springs though ie. too low for stock rims)
cheers
bly
  • 1 month later...
Hey Guys
Dam pits f**ked me over with the Pod Filter and now looking for a Standard Air Box Filter for a R33 to Pass does anyone have one I can buy?
I'll get ya free entry to Metro City aswell :)
email me at [email protected] if ya can help
Cheers
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
