ok i know this is a dumb question but has anyone re used a hks (or other) metal intake gasket on an rb26, the one closest to the head, i torqued it down left for a few weeks, engine hasnt been run, but now need to take the bloody part off,
or does anyone know where i can buy this particular gasket by itself in metal form without buying a whole kit
https://www.sau.com.au/forums/topic/287641-prob-a-dumb-question/
You can reuse your MLS headgasket. Just remember to clean it and copper spray the gasket before installing.
also has anyone had issue's running the stock gasket in high boost applications, say in the area of 25 psi?
The stock gaskets have been known to blow at stock boost levels due to age (or upping the boost from stock), the intake manifold and throttle body gaskets on GTRs are paper.
    • Probably being in IT for 2 decades, and spending my time documenting trees worth of shit and also being on the receiving end has taught me a thing or two.
    • Why's that depressing, wouldn't it be able to go indefinitely until the battery gets old and craps itself? If it's constantly on charge/maintaining charge, won't that keep the battery healthy?
    • One of my concerns initially was if something catches fire somehow.
    • I think I know what you mean. I saw the same thing a while back, I think either the images on the website were wrong or the model was slightly updated. It was weird when I first looked at it, same model but different looking unit.
    • At work we've got a smaller version of the Projecta that Duncan posted above. At home, I have an ALDI trickle charger. Ive had it for about 8 years now. Only issue with it, it's a smart charger, so if the battery is dead, it won't bring it up, but I have a variable power supply that I limit current on, and set to a max of 14.4v. once it starts charging up, I put the aldi unit on and remove the variable PSU. ALDI one will do 12v, or 6v, then has mode for "car" "motorbike", and "snow". With car or motorbike more for its internal workings, and snow is the trickle mode. I have a battery in the garage that lives on this charger for about the last 18 months now on Snow mode. When I need to charge my other batteries (eg, ones that have died in a car), I get them started and then run it on car mode. Voltage is always sitting really nice, and hasn't killed a battery yet. that charger isn't good for things like Lithium batteries etc, I'd only use it on Lead Acid.
