Hi SAU
Decided to wreck my R33 s2 and not repair after a side on.
This car was in mint condition with 93,000klms.
So here is the list: By all means PM me if anthing your after is not listed.
R33 gtst s2 Complete 93,000 klms engine $2000
R33 gtst s2 gearbox $1600
ECU to engine Harness $220
ECU $150
Radiator $150
K SPORT height and Damper adjustable suspension $1000 (less than 5klms near new)
Air filter with adapter $80
cat back exhaust $350
front bar complete with foggies $450
front guard lhs or rhs $100
bonet r33 s1 in black $250
RHS R33 s2 headlight $280
front grill $150
front reo bar $220
rear bar $120
m spec side skirts $150 pair
m spec rear pods $120 pair
Door $150 each
Mirrors $80 each
taillights $90 each
Skyline rear garnish $60
boot lid $100
s2 rear spoiler $100
brake light $60
GT badges $55 delivered pair
Front m spec lower lip $150 couple cracks in plastic
Power window motor with regulator $150
Power window Drivers switch $95
front seats $300 pair complete with rails
rear seat $150
Door trims $90
s2 Steering wheel with airbag $270
rear parcel shelf $90
r33 s2 gear surround $90 very good nic
Drivers PW surround $90
climate control unit $90
Complete 5 stud setup $1000 (Will separate bits; PM me).
Lower control arms $100 each
Front hubs $120 each
Hand brake cables $150 pair
Front rotors $100 (near new)
Rear rotors $90
Front Calipers $350 pair
Rear Calipers $250 pair
LOCATED SYDNEY: HAPPY WITH PICK UP OR DELIVERY AT BUYERS EXPENSE.
ANY BITS NOT LISTED PLEASE PM ME. :)
https://www.sau.com.au/forums/topic/287649-r33-s2-gtst-1996/
  • Replies 85
Posted Images
Hi SAU
ECU $150
Radiator $150
front grill $150
front reo bar $220
rear bar $120
Door $150 each
Mirrors $80 each
taillights $90 each
boot lid $100
brake light $60
rear seat $150
Door trims $90
Rear rotors $90
ANY BITS NOT LISTED PLEASE PM ME. :ph34r:
Hi there I would be interested in a bunch of parts.Front and rear bars skirts with pods lower lip r/h/r tail light and r/h/r qtr panel cut long to include drivers sill panel. The Please call or e mail me Thanks
[email protected]
Dean 0407628612
Hi SAU
ECU $150
Radiator $150
front grill $150
front reo bar $220
rear bar $120
Door $150 each
Mirrors $80 each
taillights $90 each
boot lid $100
brake light $60
rear seat $150
Door trims $90
Rear rotors $90
ANY BITS NOT LISTED PLEASE PM ME. :P
would be interested in the bonnet and are series 1 and 2 gtst guards the same if so i would be interested in the right one and require a grill also.will organize freight to tassie.cheers
just wondering if u have ur series 2 bonnet still in good nick.
let me no if u do n how much
[email protected]
or call or txt. 0439 676 835
K sport coilovers sold.
Pms replied to.
also after steering wheel if ur willing to drop the price
let me no
Hey mate, hope sales are going well.
I'm interested in purchasing the front rotors, driver's window master switch and driver's window motor (without regulator, as it's not required and I'm in Perth).
Please contact me via email: [email protected] or mob: 0402404192
Cheers!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
