R33 S2 Gtst 1996
Hi SAU
Decided to wreck my R33 s2 and not repair after a side on.
This car was in mint condition with 93,000klms.
So here is the list: By all means PM me if anthing your after is not listed.
R33 gtst s2 Complete 93,000 klms engine $2000
R33 gtst s2 gearbox $1600
ECU to engine Harness $220
ECU $150
Radiator $150
K SPORT height and Damper adjustable suspension $1000 (less than 5klms near new)
Air filter with adapter $80
cat back exhaust $350
front bar complete with foggies $450
front guard lhs or rhs $100
bonet r33 s1 in black $250
RHS R33 s2 headlight $280
front grill $150
front reo bar $220
rear bar $120
m spec side skirts $150 pair
m spec rear pods $120 pair
Door $150 each
Mirrors $80 each
taillights $90 each
Skyline rear garnish $60
boot lid $100
s2 rear spoiler $100
brake light $60
GT badges $55 delivered pair
Front m spec lower lip $150 couple cracks in plastic
Power window motor with regulator $150
Power window Drivers switch $95
front seats $300 pair complete with rails
rear seat $150
Door trims $90
s2 Steering wheel with airbag $270
rear parcel shelf $90
r33 s2 gear surround $90 very good nic
Drivers PW surround $90
climate control unit $90
Complete 5 stud setup $1000 (Will separate bits; PM me).
Lower control arms $100 each
Front hubs $120 each
Hand brake cables $150 pair
Front rotors $100 (near new)
Rear rotors $90
Front Calipers $350 pair
Rear Calipers $250 pair
LOCATED SYDNEY: HAPPY WITH PICK UP OR DELIVERY AT BUYERS EXPENSE.
ANY BITS NOT LISTED PLEASE PM ME. :)
  • Replies 85
Posted Images
Hi SAU
ECU $150
Radiator $150
front grill $150
front reo bar $220
rear bar $120
Door $150 each
Mirrors $80 each
taillights $90 each
boot lid $100
brake light $60
rear seat $150
Door trims $90
Rear rotors $90
ANY BITS NOT LISTED PLEASE PM ME. :ph34r:
Hi there I would be interested in a bunch of parts.Front and rear bars skirts with pods lower lip r/h/r tail light and r/h/r qtr panel cut long to include drivers sill panel. The Please call or e mail me Thanks
[email protected]
Dean 0407628612
Hi SAU
ECU $150
Radiator $150
front grill $150
front reo bar $220
rear bar $120
Door $150 each
Mirrors $80 each
taillights $90 each
boot lid $100
brake light $60
rear seat $150
Door trims $90
Rear rotors $90
ANY BITS NOT LISTED PLEASE PM ME. :P
would be interested in the bonnet and are series 1 and 2 gtst guards the same if so i would be interested in the right one and require a grill also.will organize freight to tassie.cheers
Hey mate, hope sales are going well.
I'm interested in purchasing the front rotors, driver's window master switch and driver's window motor (without regulator, as it's not required and I'm in Perth).
Please contact me via email: [email protected] or mob: 0402404192
Cheers!
 Share
    • Thanks gents, I think I'll get a PSR and see how it goes. I saw an interesting video in YT where a guy stripped one and the bearings were similar to the GTX series instead of the newer G series, but for 40% of the Garrett price I suppose there has to be some sort of trade off!
    • My opinion is they aren't worth double at all.  Have used a good number of Pulsars with builds I've been involved with and tbh at least speaking for myself, Garrett aren't losing money they'd be getting if Pulsar didn't exist as for genuine Garrett money I'd probably be buying something other than Garrett.    We've used Pulsar 6262G (G35 900 equivalent) on an RB26 with a twin scroll hotside and it picked up 40wkw at the same boost over the old twin -5s and the improvement in transient response over the twins changed the car - this is before you factor in the amount of further headroom of the G35.  Have also used one on a 2JZ drag car which has run 9.6 @ 141mph not even trying, from what we've seen so far it'll potentially go 8s when we turn it up  Crazy results for what is basically a NZ$1500ish turbo.
    • Mate i've used PSR turbos for years now and have never had an issue with them, the wheels measure the same as the real thing and i've seen them make the exact same power on the dyno pretty much back to back. Its upto you whether you'd want to spend the extra cash.
    • Sorry to change topics here, but does anyone know where to get the O-ring for the radiator drain plug?  I want to change the coolant this weekend but the manual says we should not reuse the radiator drain plug O-ring again? I did some Google search and is now getting bombarded with ads for a radiator drain plug kit 🤣 is that the O-ring? (posted pic of said ad) PS: @PranK Looks like I just needed a higher rank to post pics! It works now 🙌🏾
    • more new rubbers and to add to the mix  also new bolts for the center garnish and pretty much all done, the alarm is being replaced and I’ll deal with that ugliness when that happens
