  • Replies 60
I just came... again. Seen it in flesh a few times but just like porn, can watch it over and over again!
Kudos to you fellas for building the finest track attack car on this land!!
I want a full flying hot lap,,,none of this ending coming onto the straight malarky. We all know you two have it on your puters and an sd thingy.
Neil.
there were no real "hot" laps that day. it was tyre testing and sorting out a few little thing. mark was making his undies brown from about the second lap onwards due to those little bugs getting ironed out :blink:
wooster...i'll spew if you get to drive it before me!! lol
well i just broke a record i reckon....brisbane to darwin in just over a day and a half pulling a caravan! haha
average speed was above 130 and got booked at 137 at roma ( damn it).
highest speed was bout 150 on the highway the other side of mt isa!
but back to the r34 , yeah the tracktimes were good but there should be atleast another full second or so in it yet. the steering was locking up on some corners,
not sure whether this is due to rack being severely bumped out or fluid surge but need to look at it.
also need a better rear diff and a rear swaybar. and for eastern creek and bathurst in two months a taller diff ratio as it was hitting the limiter at the start /finish line on the front straight.
and of course, up the power which has not been touched since the initial tune.( but of course this wont be touched until the thing is handling as good as we can get it)
anyway hope to see you guys again soon
bloody hot up here!!
cheers russ
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
