average speed was above 130 and got booked at 137 at roma ( damn it).
highest speed was bout 150 on the highway the other side of mt isa!
lol that's faster than you went at the Maryborough sprints... (or any of us for that matter!) Weren't you heading up that way only a couple of months ago when you dropped into wheels on wide bay for a look this year?
P.S. what's with you not getting a drive yet Russ??! :thumbsup:
  • Replies 60
lolol , well sorry Russ but seems I'm now Johnny on the spot :happy: .... not my fault you moved up there! :D
You were damn lucky not to get the fine for 140 mate, instant loss of licence! Did the big 'cruiser get up without needing 5 litres of oil topped up? lol :thumbsup:
come on troy. do the bathurst sprint. it's probably the same dough as 2 days at spa. but it's BYO car!!! and some might argue bathurst is as good as spa. well for an aussie it's as close as we get!
well with some cash coming my way I might be tempted to do spa with you big boy... ;) would have to take the gf too, but she can go looking at waffles or whatever else they have in belgium on those days.
  • 3 weeks later...
I can very happily confirm I drove the thing yesterday and the mirror is solid as a rock now ;)
I came out late and did not get to see your run mate but I heard that you went into the 53 :P
You know you gotta give more feedback about the drive than just a short blurb on the mirror you know :P
And you didn't come say hi?!?!
Mid 54's actually, but in my defence I'd never driven that track layout before, or the car obviously, quite a bit to learn in six laps :O
The car is amazing, Mark said my eyes were like dinner plates when I stepped out, it's such a sweet little handler, but the standout for me would have to be the gearbox, wayyyyy cool that is!
Oh, and having all wheels spinning in 5th gear at the bump between turn 1 and 2 is pretty funky :)
Yeah we discussed it getting a passenger seat yesterday, will be difficult due to the muffler box but we'll try. Other peeps neeeeed to experience this car!
And funnily enough, I'm the only person other than Mark to have driven it..... the back of my throat is bruised. haha :)
OMG! You got to drive that ;):O:O You get to do everything your my hero! :):P A passenger seat is a must! If there is a will there is a way..Getting a hot lap in that would top my ride in a radical I reckon :O
*I really need to read the above posts" LOL
Sure, its a nice car. But you cant tell me you didnt jump from it just itching to get behind the wheel of an RB20 powered BOHEMOTH GTSt ! :)
haha I might be joining this RB20 clan shortly! They better be all you guys crack them up to be....
P.s Roy your car is a personal favourite of mine..Loved it on song at DECA!
Mate, with eyes that large even girl would stay away from ya :P
Seriously, I got out there quite late and a lot of people went home aldready. Briefly spoke to Mark and did not know that you were out there until I talked to Dazmo in the evening.
That is an awesome time for first time on that track and in the car. Hope you get some more practice with it ;)
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
