I am not particularly up with whats a good time at tracks, But just how is this thing looking compared to a Taxi? And would a gtr with the freedoms of taxi racing be too different (Anyone who feels like pointing out that a gtr built to those specs would have a 5litre pushrod V8 and live axle, I an not asking how a Taxi would go compared to a Taxi) I have long wondered just what would happen if a GTR was built to similar guidelines.. How much would we beat them by now?
  • Replies 60
Dont make the mistake of thinking that V8 Supercars have plenty of freedom in the rules. Revs, weight, compression, suspension components, a horribly small control tyre. Limited aero etc etc all mean that given a clean sheet of paper a team could make the cars go far quicker. Keep in mind that at some track Carrera Cup cars are as quick-quicker then the Supercars.
They are still race cars, but free up some of the rules and the teams could make the cars lighter, bigger tyre, better aero and more power.
But would be interesting....like any form of tin-top motorsport, any car with a technical advantage will be hobbled to allow for other makes to compete.
Correct, the V8's aren't cutting edge stuff, but they are developed to within an inch of their capability.
Having driven the 34 I can say it definately feels hobbled by tyres. Not taking anything away from the Yoki Advan, I'm sure they're great, but the car deserves a full slick. Obviously trying to develop the thing for Superlap events means tuning it on slicks is a waste. Regardless, for Bathurst it will be on slicks.
Talking with dave who designed the suspension on wednesday (and builds V8's too), he says there is absolutely no reason the 34 wouldn't be quicker on a comparable tyre. And that fairly obvious when you flesh out the specs of each.
** entered for Lakeside on the 17th........ BE THERE!
hell yeah! there better be video - footage like you got with the speed and stuff overlayed would be awesome!
I can't make it there, will be camping at Fraser...
will be very interesting to see what times it does!
Edited by hrd-hr30
The R34 is going to bathurst???
Do you guys just do super sprints??? Marlin, Harry??
yeah, just the occassional sprint for me these days. I've had a bit of a resurgance of interest since Lakeside re-opened. Probably done as many sprints in the past 18 months as the previous 5 years put together!
Have done a bit of rallying in the past, both classic rallies and a few gravel/forest rallies. If it wasn't so expensive I'd love to have another crack at the forest. Nothing comes close to its adrenaline rush!
I was wondering if you got into the low key race meetings...grassroot gridracing sort of stuff?? I am involved with a race series and will be coming up that way in 2010
Rallying is awesome fun even in the passenger seat..I am addicted :)
Yes Jess, it will be at the Drive Bathurst meeting :D
super sprint or the other one? So many question..I always ask questions :merli:
Oh I would love that car to go up against Jim Richards Porsche!!!
Yeah thats the one. I was going to enter, then I woke up and realised the chemist won't sell me enough Codral to afford to enter.
Aww I feel your pain! You should enter speed weekend in December..Thats if your not doing Mt Buller
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
