BTW, I picked up yet another set of wheels from Yahoo japan. I know what you guys are thinking, but I just love this JDM stuff!
The obligatory pictorial:
Specs:
Fabulous Expand Racing R, Forged, high quality, brand new
19"X10.5" +22 offset; same as my previous Rays CE28Ns
Mega lip and plenty of 'bling' 'bling'
No blow off valve. The key is stealth. You will be surprised how quiet the engine/exhaust sound is at idle, almost stock. When you rev it high, it howls much like the Mines R34 car.
Tangomatt, i love everything about your build so far...but im just not seeing the excitement in these rims.
couldn't agree more.. :) but i suppose it might all fall into place when on the car..
as for seeing it in action, bring it to a deca thats no doubt the safest place to give it a flogging
Just read through your build and Im crushed lol I so want to build up my car like this but yeah dont have the available funds yet, but well done on it great to see the commitment you put in and stuck through it and got it finished its unreal the car. PS you really love your rims lol.
Very sweet car. <-- understatement of the year...
I will say one thing however - you have way too much $$ for your own good... :rofl2:
If you don't mind me asking, how much has this all cost you (roughly)?
Edited by gwilkinson34
Nobody will ever answer that question.
Usually because all the recepits have been thrown out. This way your not tempted to add them up and weigh the dollars spent with the fun you get from the car. And of course no reciepts means it technicaly cost nothing!
I honestly don't know exactly how much has been spent on this project as I have bought and sold parts along the way.
One thing I know for sure is that there are many other builds in this forum that cost much more than mine. :down:
One thing I know for sure is that there are many other builds in this forum that cost much more than mine. :D
Yeah!? Really!? Like who!? Tangomatt, we all know you're being modest. :)
Edited by AtomicBomberMan
Hi all,
Just a quick update on the suspension upgrade with Racepace customised Tein RS setup.
The Tein RS, aka 'Circuit Master; Super Racing Spec', has been out of production since 2006-2007. They were the top of the line in the Tein catalogue for production cars at that time. In some ways, I feel that the materials used and the way it was manufactured surpass what's commonly available today, even the premium priced shocks.
Details of the RS are listed below (sourced from US based my.is forum in 2002)
MATERIALS AND FACTS:
DAMPING MECHANISM:
45mm diameter pistons
Double shim stacks (near unlimited tunability with knowledge of shim valves)
Two 'special form' adjustment needles
SHOCK/RESERVOIR BODY:
Monotube shock body
53mm outer diameter
Aluminum alloy (A7050) seamless tube, CNC'ed, green (hard?) anodized
Inner tolerances:
diameter: ±5µm
roughness: ±1.6µm
Reservoir body interior is PTFE (Teflon) coated
CNC'ed aluminum alloy eyelet, Tein rubber bushing, steel pivot
SHOCK SHAFT:
14mm diameter
Chromoly (SCM435) steel, Ti-N coating
SHAFT SEAL/GUIDE:
WRC spec
PILLOWBALL MOUNT:
Aluminum alloy, CNC'ed, powdercoated (gold)
SPRINGS:
Main and helper
Steel, ground and tapered, enameled
10K front, 10K rear
SPRING PERCHES:
Aluminum alloy, forged and machined
SETTINGS:
-34mm front, -12mm rear (easier measured as 335mm both from the center of the wheel to the fender lip, front and rear)
10 clicks rebound front
10 clicks compression front
10 clicks rebound rear
13 clicks compression rear
Out of the box, the RS will not suit my purpose of a street orientated setup in Australian conditions. So the solution Racepace derived is to employ a high quality, well engineered shock to begin with and customise the valving and spring rates.
The current spring rates are less than half of 10K front and rear. The exact rate Racepace did not divulge and so is what they did to the revalving. BUT believe me, the setup works very very well.
My initial impression, compared to the Nismo S Tunes, which is also street orientated:
- The damping is comparable, soaks up bumps and road undulations well. The rebound is quicker than the S Tunes, that the RS is less 'cushy'
- The car feels more planted and can hold its intended steering path despite mid corner bumps etc
- At very low speeds, the RS is very compliant
The only annoying thing is an annoying 'whimper' originating from the rear shocks at very minute bumps. It almost sounds like someone rubbing a wet finger on clean glassware. However, I did some research and found that this is quite common, and indicates no fault. The pillow ball mounts also transfer more road noise to the cabin.
I spent a good afternoon with Chris from Racepace. And this is how I feel as a passenger..... Well Chris test drove the car in a 'hill' run. (Chris is an excellent driver btw. He scared the sh*t out of me)
- The car feels like its on tracks and bumps do not upset the momentum.
- Car feels planted, period!
Chris comments that the RS allows him to transfer weight nicely and from the get go the setup is confidence inspiring. That is he can drive a lot quicker if I was not in the car with him. He was extremely happy with the way the RS can handle the low speed stuff equally as well as the high speed.
Overall, I am very impressed, bearing in mind that the Nismo S Tunes were very good to start with. I highly recommend it to anyone wanting a street car to go for less spring rate but good damping force.
Final thing on the agenda - increase ride height on front end and transfer case reinforcement.
PS will post pics on weekend.
Cheers
Matt
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
